I need some recommendations for a graphics card upgrade for my PC with a Ryzen 7 5700x.
JojoMonks
I currently have a 1650 super and I really need to upgrade as it is seriously bottlenecking my CPU. I would like to know what you guys would recommend for my situation.
A 7800 XT would be a damn good upgrade and would run well on the 5700x.
Is this within your budget?
Yeah I was looking at those and
Yeah that would probably be within my budget, I am waiting for some sales to start in the coming months. I just was stuck trying to figure out where to go with the hardware. 7800XT looks like it would be a good upgrade, any recommendations on a specific board partner to go with?
Awesome!  The 7800 XT absolutely demolishes the 1650 Super!
Just make sure you have enough wattage from your power supply, it also requires 2x8pin power connectors.
When it comes to board partners I would say it also depends on the sale.
The Gigabyte OC looks to be quite decent.
Alright thanks for the help. yeah I'm not home currently so I can't check but I believe I have a NZXT 750 watt and I still have the bag of all the cables so it should be a non issue.
A 750w will be plenty enough for the 7800 XT plus the rest of your system, absolutely no problem there 🙂
Just check for 2x8 pin PCIE power cables and you are golden!
If you prefer Nvidia then a 4070 would be equal to a 7800 XT.
Here a video you can skip through 🙂
Keep me updated! 🙂
If you have any further questions just tag me here.
Oh, and welcome to the Forums!
I'd get something cheap, because there are so many cards around this price range, e.g. 7800 XT, 7900 GRE, 4070, 4070 Super.
If you overspend $50 you go from good deal to bad deal.
6800 non-XT is one to consider too, if you can find it.
What games/resolution are you playing?
I am playing mostly war thunder and ready or not, however I would like to play satisfactory but it barely runs. I play at 1080p 60hz I will upgrade my display further down the line I just need something to play satisfactory because it's a resource hog.
Look at the 7900GRE if you're moving up to 1440p.  It's a fantastic card for the resolution, will be for years.
Satisfactory runs fantastic on AMD cards, playing right now on my 7900XTX.   Settings on HIGH, frame limit of 120Hz.  41% GPU utilization.    Runs very well so far ,but still in the early stages of the game.  Can;'t wait to see how the XTX chews thru a fully built factory.
Onyx AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
DIL: Ryzen 7800X3D - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 CL6000CL32 32GB - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
GF Rig: Steam Deck 512GB OLED
OnePlus Ecosystem:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
I'll look into it, I'm probably going to base my decision on what the deals are at the time I do end up purchasing this, I was able to play satisfactory on low pre 1.0 but it runs worse for me now with 1.0 and low settings is no way to play that game. Once you have your factory built I would at least turn them down to see it because some of the textures look really silly.
