Constant Resets and High Temps After Upgrade
Raigas
I recently upgraded from an i9-10850k to a 7800X3D, and transitioning to AMD has been a nightmare. My PC keeps constantly resetting, and even if I manage to get into Windows, it resets again. Additionally, my GPU temps are high. I didn’t have this problem with my i9-10850k.
My specs are: Zotac RTX 3090, NZXT X73, Revolt X Series 1000W PSU. I'm using the AM4 bracket, but I'm not sure if the AM5 bracket matters. The CPU temps are also quite high.
What do you mean by bracket?
You need to add more info.... how high are the temps....what cpu cooler do you have etc etc.
You can never provide too much information.
CPU : Ryzen 7 7800X3D @ -30mv All core
CPU Cooler : Thermalright Frozen Prism 240mm AIO
Mobo : Asrock B650m Pro RS Wifi
Ram : 32GB (2X16GB) Lexar Ares 6000MHZ CL 28-36-36-68
GPU : MSI Gaming X Slim 4070Ti Super 16GB ( 308W PL +140 Core +1000 Memory )
Storage : 2TB Verbatim Vi5000 Gen 4 NVME
PSU : Thermalright TG-750w 80+ Gold ATX 3.0 PCIE 5.0
Case : Fractal Design Pop Mini MATX
Case Fans : 3 X Thermalright TL-C12C-S RGB
Monitor :27" Samsung Odyssey G5 2560 x 1440 180 HZ IPS
Keyboard : HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
I did include the CPU cooler nzxt x73, which comes with two types of brackets: AM4 and AM5. However, at the time I bought the cooler, it didn’t include the AM5 bracket because it didn’t exist yet. They recommend using the AM5 bracket now, but I'm not sure if there's an actual difference. Either way, my CPU idle temperature is around 60-70°C, while the liquid temperature is only around 33°C. My GPU shows 55°C at idle, but the backplate feels really hot to the touch.
You can get the AM5 bracket from NZXT.
https://nzxt.com/product/kraken-xz-am5-upgrade-kit?srsltid=AfmBOordruf-wz1iLnMqDEOgUiLAx6GAJwI5VP8EvK9Ugx0TzXkoj2SD
Is your nzxt pump plugged into a separate header from the cpu fan and the speed changed maximum?
