Weird display/audio connection issues with new CoPilot + pc - Samsung Galaxy Book 4 Edge
Go to solution Solved by NumLock21,
Some of the branded docks are designed to be used only with their own products, so any 3rd party devices used can be a hit or miss.
Try updating the firmware
Hello!
First time poster here, wasn't really sure where else to turn. I recently purchased a Samsung Galaxy Book 4 Edge, 16 inches, the 512gb model. When connecting to a dell dock, via one of my usb c ports I am running into all sorts of buggy issues with the dock.
Some things that have happened:
  • Screen just goes black and can only see the mouse show up on the screen when I move it
  • Nothing - meaning no image on the plugged in displays
  • It not saving my display settings from the last time I plugged it in.
  • It completely hard crashing my computer and making it reboot
All of those things I've figured out can be resolved by a restart, or turning HDR off (which seems to continue to be the bane of windows machines...). Or strangely enough, just plugging the dock into the other usb c port (which shouldn't matter as they are both rated for the same speed I believe?).
The most infuriating part about all this is the audio just simply won't work when plugging into the aux port on the doc.  I can switch to the onboard speakers and sounds come out those, but I can't get it to pick up the signal through the port. The reason that this drives me up a wall, is because I have gotten it to work, but I can't seem to trouble shoot a solution to get it to work again.
The Dell Dock I am using is the WD19 - Link here
I do realize there is plenty of things to overcome with these new ARM laptops and wouldn't be as persistent about it if I hadn't gotten it to work before. Any help would be appreciated.
Intel Xeon E5 1650 v3 @ 3.5GHz 6C:12T / CM212 Evo / Asus X99 Deluxe / 16GB (4x4GB) DDR4 3000 Trident-Z / Samsung 850 Pro 256GB / Intel 335 240GB / WD Red 2 & 3TB / Antec 850w / RTX 2070 / Win10 Pro x64
HP Envy X360 15: Intel Core i5 8250U @ 1.6GHz 4C:8T / 8GB DDR4 / Intel UHD620 + Nvidia GeForce MX150 4GB / Intel 120GB SSD / Win10 Pro x64
HP Envy x360 BP series Intel 8th gen
AMD ThreadRipper 2!
5820K & 6800K 3-way SLI mobo support list
Hey! Thank you for this, it solved the issue. Everything is working how it should now. Much appreciated!
