Fan RPMs not showing up in BIOS. Is the hub to blame?
Solved by matt0725,
i believe a hub will only report 1 fan (or maybe the average of connected fans) RPM, but it doesnt really matter in the end, as they are all going to be spinning roughly the same RPM anyway, as they get controlled off of the same plug. If you want each fan to be controlled on its own, youll need enough extensions for those shorter fan leads, plus enough fan headers on your motherboard
Featured Topics
Sarath0508 ·
Posted in General Discussion6 -
tycho513 ·
Posted in Build Logs0 -
3
1
Zerlargal ·
Posted in General Discussion1 -
2
SS451 ·
Posted in General Discussion10 -
play_circle_filled
Latest From Linus Tech Tips:
Are You All Geniuses or Idiots? - Reacting to Your Best Tech MacGyvering
play_circle_filled
Latest From Tech Quickie:
Windows Used to Sell a Cheap Version. Here's Why They Stopped
play_circle_filled
Latest From ShortCircuit:
This time iPhone users are missing out - Google Pixel Buds Pro 2
play_circle_filled
Latest From Mac Address:
I found the CHEAPEST new Macbook. Is it better than a PC?
