B650M Colorfull RAM Led
By
Mikeeel
in Troubleshooting
in Troubleshooting
Solved by Sawa Takahashi,
Just now, Mikeeel said:Thanks, I don't have friends with AM5 builds so cant do that. I will try remounting the cpu
Repair shops should be able to test your CPU easily (and maybe for free). If you have no other choice, you may also be able to purchase a CPU and return it if it doesn't solve your issue (just ask and get written consent before buying).
Featured Topics
thephantom8768 ·
Posted in New Builds and Planning1 -
1
1
Mistikoje ·
3
Sealance ·
Posted in Graphics Cards3 -
3
ServalNullXero ·
Posted in Displays1 -
play_circle_filled
Latest From ShortCircuit:
I Can’t Believe I Care about a Motorola Phone…. - Motorola Razr Ultra (2025)
