how do i fix ryzen 7 7800X3D stuttering
im using an ASUS rog strix x670e and seemingly at random my game will stutter, ive also noticed around the time it stutters the device security section in windows will switch from standard hardware security not supported to your device meets the requirements for enhanced hardware security.
ive read on the internet that switching off tpm will fix it but im on windows 11 and play valorant so i really dont want to do that. im using the latest bios. is there any way i can fix this? these stutters are driving me crazy.
Can you fill in how the machine was set up in the first place?  Fresh build?  Anything "upgraded"?  Drivers not updates?  BIOS?  DDU?
There are a ton of things that can impact, and usually it's a nonfresh install/build.
Onyx AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
DIL: Ryzen 7800X3D - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 CL6000CL32 32GB - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
GF Rig: Steam Deck 512GB OLED
OnePlus Ecosystem:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
this is a brand new build, and my bios is on the latest version. i got cpu chipset drivers and gpu drivers from the amd website and i let windows update install everything else
And you have no physical hard drives in the system?
Full specs may help, but it sounds like you did everything right.  So outside of a bad game install or Windows issue... hardware would be the problem.
Do your drives or CPU or GPU show the stuttering in Task Manager usage?  Or any temp issues in HWInfo64?
I am unsure how to diagnose a stuttering like that, or to prove what causes.
OnePlus Ecosystem:
Other Tech:
No hard drive, my bad for not clarifying that earlier
My specs are
Asus rog strix x670e
AMD Ryzen 7 7800x3d
Corsair Vengeance 2x16 6000mhz
And rx 7900xtx
Samsung 990 pro 4tb
I don't think anything is showing in the task manager but I can send a screenshot later today. I'm 99% sure it's the tpm because whenever I turn it off my game doesn't stutter
