Advice for my first m.2
Mitchell.judson
Go to solution Solved by kokosnh,
From 1TB I see T500 for 88$ sold by Amazon.ca
https://www.amazon.ca/Crucial-Internal-Gaming-Desktop-Compatible/dp/B0CK39YR9V
It’s Phison E25 + ddr4 + 232l TLC micron
it’s just a little worst then top of the pcie 4.0 ssd. It’s a good pcie 4.0 ssd with DRAM on TLC from reputable brand.
it’s really good deal, if you want to buy 1TB, buy now.
it will be better than any PCIe 3.0 ssd
and yes, pcie is backwards compatible, you can use PCIe 4.0 ssd in pcie 3.0 slot ( even I do that )
Hey everyone looking at getting my first m.2 drive in the next day or two, I'm planning on moving my os and main files to it, freeing up one of my sata ssd's for more game storage as most of my games are on hdds( old 5400rpm hdds). The two options I'm looking at are the crucial p3 gen 3 1tb for 79.99, or the Kingston nv2 gen 4 1tb for 78.99. I'm leaning towards the crucial for obvious reasons, but is there a reason to consider the Kingston instead?
* I'm only running a 5600g so I can't use gen 4 speed. *
NV2 hasn't; gotten the best reviews, so if it's the choice between the 2... I'd opt for Crucial.
I'd personally look at the TeamGroup MP44L, it's affordable and a solid drive.
Onyx AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
DIL: Ryzen 7800X3D - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 CL6000CL32 32GB - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
GF Rig: Steam Deck 512GB OLED
OnePlus Ecosystem:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
I had noticed the teamgroup as well when I was browsing, I may have to take another look at it
Thanks a bunch
Why don't you get one of the 2TB M.2 NVMe drives for 95USD ?
I'm willing to swim against the current.
Kingston NV2 is a budget NVME with technically PCIe Gen4, but in actual it's comparable to proper Gen3 speed
Based on TechTesters review, when it comes to performance it's quite on the lower scale
I do use 2TB of Kingston NV2 for mass storage for 1,5 years, and the only reason I choose it because Crucial P3 is not officially sold in my region, so Kingston is the one and only option for me (and I didn't realise to check on Amazon since I'm used to checking on local market place instead of Amazon)
If your region has access to Crucial P3 with similar price to Kingston NV2, I would suggest to take Crucial instead for better performance (although you probably won't see much benefits unless you transfer data a lot)
YouTube reference:
My System: Ryzen 7800X3D // Gigabyte B650 AORUS ELITE AX // 32GB 6000MHz DDR5 Silicon Power Zenith CL30 // Sapphire Pulse AMD Radeon RX 7900 XT OC with mod heatsink on the metal plate  // Phanteks P300A  // Gigabyte Aorus GEN4 7300 PCIE 4.0 NVME // Kingston NV2 Gen4 PCIE 4.0 NVME //
Seasonic Focus GX-850 Fully Modular // Thermalright Frost Spirit 140 Black V3 // Phanteks M25 140mm // Display: Bezel 32MD845 V2 QHD // Keychron K8 Pro (Mod: Gateron black box ink; Tape mode on PCB and Keycaps) // Razer Cobra Wired Mouse // Audio Technica M50X Headphone // Sennheiser HD 650 // Genius SP-HF180 USB Speaker //
And Laptop Acer Nitro 5 AN515-45 for mobility
Phone:
iPhone 11 (with battery replaced instead of buying new phone for long term and not submitting (fully) to Apple Lord
P3 is a Phison E21T + 176l QLC micron nand
nv2 in 1TB variant have 11 different hardware versions, first they were on TLC, later they swapped to QLC.
SM2267XT/SM2269XT/phison e19T/e21T and 6 versions on TLC, and 5 on QLC ( now they are on QLC )
and that is only the 1TB variant…
so both are horrible ssd, but well cheap…
where are you buying from? USA?
is there no at least sn570/sn580 etc
CPU : Intel 14gen i7-14700K
COOLER :  Thermalright Peerless Assassin 120 White + thermaltake toughfan 12 white + Thermal Grizzly - CPU Contact Frame Intel 13./14. +  Coollaboratory Liquid Ultra
GPU : MSI RTX 2070 Armor @GPU 2050MHz Mem 8200MHz -> USB C 10Gb/s cable 2m -> Unitek 4x USB HUB 10 Gb/s (Y-HB08003)
MOBO : MSI MEG Z690 UNIFY
RAM :  Corsair VENGEANCE DDR5 RAM 64 GB (2 x 32 GB) 6400 MHz CL32 (CMK64GX5M2B6400C32)
SSD : Intel Optane 905P 960GB U.2 (OS) + 2 x WD SN850X 4TB + 2 x PNY CS3140 2TB + ASM2824 PCIe switch -> 4 x Plextor M8PeG 1TB + flexiDOCK MB014SP-B -> Crucial MX500 2TB + GoodRam Iridium PRO 960GB + Samsung 850 Pro 512GB
HDD : WD White 18TB WD180EDFZ + SATA port multiplier adp6st0-j05 (JMB575) ->  WD Gold 8TB WD8002FRYZ + WD Gold 4TB WD4002FYYZ + WD Red PRO 4TB WD4001FFSX + WD Green 2TB WD20EARS
EXTERNAL
HDD/SSD :
XT-XINTE LM906 (JMS583) -> Plextor M8PeG 1TB + WD My Passport slim 1TB + LaCie Porsche Design Mobile Drive 1TB USB-C + Zalman ZM-VE350 -> Goodram IRDM PRO 240GB
PSU :  Super Flower leadex platinum 750 W biały -> Bitfenix alchemy extensions białe/białe + AsiaHorse 16AWG White
UPS :  CyberPower CP1500EPFCLCD -> Brennenstuhl primera-line 8 -> Brennenstuhl primera-line 10
LCD :  LG 32UD59-B + LG flatron IPS236 -> Silverstone SST-ARM11BC
CASE :  Fractal R5 Biały + Lian Li BZ-H06A srebrny + 6 x Thermaltake toughfan 14 white + Thermalright TL-B8W
SPEAKERS :  Aune S6 Pro -> Topping PA3-B -> Polk S20e black -> Monoprice stand 16250
HEADPHONES :  TOSLINK 2m -> Aune S6 Pro -> 2 x Monoprice Premier 1.8m 16AWG 3-pin XLR -> Monoprice Monolith THX AAA 887 -> 4-pin XLR na 2 x 3.5mm 16 cores OCC 2m Cable -> HiFiMAN Edition XS -> sheepskin pads + 4-pin XLR na 2 x 2.5mm ABLET silver 2m  Cable -> Monoprice Monolith M1060 + Brainwavz HM100 -> Brainwavz sheepskin oval pads + Wooden double Ɪ Stand + Audio-Technica ATH-MSR7BK -> sheepskin pads + Multibrackets MB1893 + Sennheiser Momentum 3 +  Philips Fidelio X2HR/00 + JBL J88 White
MIC :  Tonor TC30 -> Mozos SB38
KEYBOARD : Corsair STRAFE RGB Cherry MX Silent (EU) + Glorious PC Gaming Race Stealth Slim - Full Size Black + PQI MyLockey
MOUSE :  Logitech MX ERGO + 2 x Logitech MX Performance + Logitech G Pro wireless + Logitech G Pro Gaming -> Hotline Games 2.0 Plus + Corsair MM500 3xl + Corsair MM300 Extended + Razer goliathus control
CONTROLLERS :  Microsoft xbox series x controller pc (1VA-00002) -> brainwavz audio Controller Holder UGC2 + Microsoft xbox 360 wireless black + Ravcore Javelin
NET :  Intel x520-DA2 -> 2 x FTLX8571D3BCV-IT + 2 x ASUS ZenWiFi Pro XT12
NAS :  Qnap TS-932X-2G -> Noctua NF-P14s redux 1200 PWM -> Kingston 16GB 2400Mhz CL14 (HX424S14IB/16) -> 9 x Crucial MX500 2TB ->  2 x FTLX8571D3BCV-IT -> 2 x Digitus (DK-HD2533-05/3)
Folks may not understand if something is bad just from listing a controller model.
Why is the prison e21t bad?
And in all honesty, does any of that impact a day to day standard user?  Or is it nit picking?
OnePlus Ecosystem:
Other Tech:
Got those canadian pesos not fancy American dollars unfortunately
I'm buying from Canada, specially east coast, for reference my closest best buy is over an hour away so I dint have much access besides online orders
EXTERNAL
HDD/SSD :
From the good 2TB ones, I only see  TEAMGROUP T-Force A440 Phison E18 + ddr4 + 96l TLC micron   for 189$.  https://www.amazon.ca/TEAMGROUP-Graphene-Aluminum-Heatsink-TM8FPZ002T0C327/dp/B0921RKRDH
or FireCuda 530 Heatsink 2TB phison E18 + ddr4 + 176l TLC microna for 195$ in Best Buy
https://www.bestbuy.ca/en-ca/product/seagate-firecuda-530-heatsink-2tb-nvme-pci-e-internal-hard-drive-zp2000gm3a023/15644371
you could go cheap with Chinese dramless controller and nand for TEAMGROUP MP44 2TB. it’s on maxio MAP1602A + 232l TLC YMTC for 160$
https://www.amazon.ca/TEAMGROUP-Cache-Laptop-Desktop-TM8FPW002T0C101/dp/B0C3VCD5Z8
EXTERNAL
HDD/SSD :
Thanks a bunch, I was leaning that way for the dram and better brand but sometimes that second voice being like don't go super cheap helps haha
