Thermalright Phantom Spirit 120SE CPU Air Cooler Wattage and fan position questions?
How many watts does the "Thermalright Phantom Spirit 120SE CPU Air Cooler" expend? Obviously what the motherboard provides it with, correct? How much would that be...
Also, how high up can I let the fans be? (Like in diagram)
I need it for an AMD Ryzen 9 7900x3d CPU.
Any advice? Should I get another cooler? Going to add my GIGABYTE AORUS 4090 GPU after i solve this.
230W at max. It will have absolutely no trouble with that CPU.
You can let the fans be as high as you want.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
Motherboard image please check 😞 it says max 12W for CPU_FAN -- do you mean CPU spending Watts? Or how much the fan sucks out of PSU?
Asus ROG Strix B659E-I Gaming WIFI motherboard...
Also I don't think the fan can be so high up... just a little higher I propose? Just for a little more clarification if you or anyone may? Just in case (I'll be testing meanwhile)
1A for a fan header is standard. How many you can connect depends on how many amps each draws. For example, if you have fans that draw .2A each, then you can have 5 attached, but if they are .21, then only 4. Trying to draw more than 1A off a header can cause it and/or the mobo to become damaged. Since you don't have an AIO, you can use all 3 headers, but make sure they are set to the correct setting (auto/DC/PWM).
You can adjust the fan height. Given that you have a cool CPU, it won't really impact the maximum TDP (oC/watt) to the point that your CPU will overheat.
230W TDP (think of it as thermal dissipation potential).
Sorry 230W was for the cpu again, correct?
And potential word's relation is... ball being uphill correct? Like potential energy, right?? Also "power draw" is when we imagine electrons moving from positive to negative or from negative to positive poles?
Because if peripheral has a power draw, then it is sucking electrons from PSU?
Which means a socket has a voltage and current in Amps? And not just voltage? I can't connect how it is a power draw and not the socket shoving 8A into a component (like a PSU) <--- this is where I heard 8A is aloooot... __AND THAT IT IS WHAT A WALL SOCKET PROVIDES!__
(P(watt) = Current(I) * Voltage(V)
      ---> 240 * 8 = 1920W...)
Which is... alot of WATTS? Or Not???
https://www.thermalright.com/product/phantom-spirit-120-se-black/
[ at mid of page in specs: "...Ampere:0.20 A..." ---> which is max of at 12V of 2.4W.. correct? ]
Assume 12W and 1A of CPU_FAN?? I'm not even sure if it is 12V...
Thanks,
-Nasser
Thanks,
-Nasser
Are you sure you're thinking about this all the correct way?
Onyx: AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 1000 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
OnePlus Ecosystem:
Other Tech:
You're getting a bit over my head with this kind of details but I'll answer what I can.
230W
TDP means 2 things.
If you're talking about a processor, for example, TDP is the max heat production expressed in watts. Yes, I find that confusing. Why they couldn't use a discrete word is beyond my ken.
If you're talking about a cooler, it is the potential maximum amount of heat it can displace, assuming optimal compatibility with the CPU. This is also expressed as watts. Sigh.
Apparently, the calculations for Intel and AMD are different, the IHS curvature are different, the chip positioning is different, etc, so what will maximally dissipate 230W on one will do less on another. 😞
Potential
Potential refers to the maximum possible heat production/ dissipation.
Electrons
This is beyond my ability to give more than a basic answer. Anything that uses electricity does whatever it is that provides the actual flow of electrity. I was taught that it is electrons moving, but a Veritasium video suggests that is inaccurate.
Socket
It doesn't draw anything. It is just a receptacle. Think of it as power outlet. The CPU is what uses the electricity,  and volts watts and amps are all expressions of that usage. I lack the knowledge to go deeper than that.
Fans
These days, most PC fans run at 12V. If it's an RGB fan, the lights draw 12V, too. If it's ARGB, 5V instead of 12V. So that 12V minimum but the important part is the actual draw. So, yes, if it's .2A then that it 2.4W.
If your fans (without lights) draw 12V and 12W, that is 12/12=1A. If they have lights, you do a separate calculation for those. And, of course, keep in mind that those numbers can fluctuate from 0 to the safety maximum, which isn't even shown on most PC fans and isn't necessarily the same as the rated value.
Hopefully, if I've made any errors, someone who's better at math and electronics will step in.
I can run my 5900X at 260w PPT with that cooler.
AMD R9 9900X | Thermalright FW Pro, 3x TL-H12-X28-S, 3x TL-P12
Asus Strix X670E-F | 32GB Lexar Ares @ 6200 28-36-36-68 1.45v
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 3x SN770, 6TB
Asus PA602, 2x 200x38, 1x 140x28 | Seasonic Vertex GX-1000
OP seems to be concerned that the fans on their cooler will take more power than the fan headers on the motherboard can deliver because they are "12 Watt."
The people answering are talking about how much heat from the CPU the cooler can handle, which is usually measured in Watts.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
Ryzen 7 5800X3D | ASRock X570 PG Velocita | RTX 3080 ti Founders Edition | 4x8GB Crucial Ballistix 3600mt/s CL16
The stock fans are pretty weak, I wouldn’t be concerned in the slightest.
The same goes for almost every other consumer grade fan out there.
Yeah.. I thought printed error or something...
Edit: sorry, I meant printing error. Like I thought maybe there are printing errors.
Edited by NazCrankHank
