Upgrade - GPU vs Monitor?
Hello guys. I was wondering whats my next best move for an upgrade. I recently got a Ryzen 5 5600 and I wanted to upgrade my GPU next, but now having tested a 180hz display its astonishing how much better it is than my 75hz display.
I mainly play FPS games at the lowest settings and rarely play GPU intensive games, though playing Delta Force, CoD and Battlefield really does require some GPU horsepower.
My build:
AMD Ryzen 5 5600
Gigabyte A320M-H (rev 1.x)
G.Skill Aegis 2x8GB 3000 MT/s
Asus TUF Nvidia GeForce GTX 1660 Gaming OC
Thermaltake BX1 550W 80+ Bronze
My current display: Dell 27 inch 75hz monitor
whats your budget?
If a post resolved/answered your question, please consider marking it as the solution. If multiple answers solved your question, mark the best one as answer.
If your PC is giving way more FPS than the monitor can handle, then upgrade the monitor, 75Hz is very low for competitive gaming
2 hours ago, anirudthelinuxwIzard said:
whats your budget?
Found a good, used AOC 24" 144hz monitor with 1 year left on warranty for 100 eur.
Also found a RX 7600 for 200...
I mean in total.
ehh, you might be fine with the gpu until black ops 6, so maybe look for a new gpu if possible. im currently on a 75hz monitor  and i can say its fine for now.
my pc (cpu is upgrading soon): https://pcpartpicker.com/list/Xt9bWt
proving budget is just as good since 2021
I mean in total.
My total budget is maximum 200.
