Random Booting Under Low Load? [PSU Works in Another System]
6 hours ago, Sefinx said:But if the issue is excessive ripple, is it more so cause of the PSU or is it still mostly our house's wiring?
Like I said before, some PSUs are more sensitive to electrical faults (or irregularities like excessive ripples). So yes, it is the PSU that is tripping but the cause is the electricity being slightly out of norm.
If you get a UPS, my guess is that it will switch often to battery power because of electrical spikes, ripples and grounding faults (assuming that it will operate correctly despite the bad grounding).
Changing the PSU for one that has higher tolerance or that has more capable filters can be a solution for your computer. Still, the solution for the whole house is fixing the electrical system.
Hope that answers your question.
