LGA 1155cpu cooler on AM4
AkaTheUnknown
Go to solution Solved by Alinz,
Nope, that one you cannot use on the AM4 platform. What CPU are you planning on buying? Most AMD CPU's come with a stock heatsink aswell.
i have an LGA 1155 cpu cooler, im just wondering if i will be able to use it on an AM4 socket?
or do i need to get a new cooler specifically for AM4
Depends of the cooler. Most coolers come with both Intel and AMD mounting kits. What cooler do ou have?
My Rig: CPU : 10700K | RAM : Trident Z Neo 3600Mhz c16 32G (4x8) | CPU cooler : NHD15 | GPU : ASUS ProArt 4070 | PSU : Corsair RM850 (black label) | CASE : Corsair 5000D Airflow | Storage : Samsung 970 evo 1TB, WD Black 1TB, Samsung evo 850 Sata SSD | Casefans : Lian Li Unifan SL120 7X|
MOUSE : G Pro Wireless X superlight | Keyboard : Keychron C1- Pro-H1 Gateron Milky Reds
its the intel stock cooler that came with the cpu
im buying a used cpu- ryzen 5 3600, 32GB Corsair vengance RGP Pro 3200mhz ram(4x8gb) and MSI X470 Gaming Plus MAX
all 3 of this. but the seller said no cooler
Oh ok I see. What is your budget for a cooler? AM4 stock coolers shouldnt be hard to find on the used market. Otherwise you can pick up something like a Thermalright Assasin for cheap.
im looking for something thats cheap, i dont have alot of budget
but thanks for the suggestion, and also the help
You're welcome, where are you based? Both options should be less than $20,- USD,
The peerless assasin is only $40, but should last you basically forever, unless you buy the 14900k, definitely worth the price
South Africa
What is your budget? From what i can tell you can buy a hyper 212 for around R 700 on evetech (i dont know if they are a reputable seller tho), I cant recomend the cheaper stuff on their site because I am not familiar with the brands
or he could just by the stock cooler off ebay for 10$.
my pc (cpu is upgrading soon): https://pcpartpicker.com/list/Xt9bWt
proving budget is just as good since 2021
Already suggested that
i found a used AIO for R500 on bobshop (our version of Ebay)
i bought that, coz my case is AIO compatible and also gives a good cpu upgrade path if i need
