Regular AirPods cheaper alternative (true wireless earbuds with multipoint but without silicone tips)?
I'm looking for a cheaper alternative to regular (non-pro) AirPods. I have three requirements:
1 - Multipoint to at least two devices.
2 - No silicone tips.
3 - <$100 USD.
Any suggestions?
your not gonna find anything that isnt an apple knock off at that price. only good ones at that price are the amazon buds. but if you do open up to silicone tips, go beats, jbl, or jlab. your not gonna regret it.
my pc (cpu is upgrading soon): https://pcpartpicker.com/list/Xt9bWt
proving budget is just as good since 2021
I have found the SoundPEATS Air4 Lite & Sudio N2, both meet all three of my requirements. I will most likely go with the SoundPEATS Air4 Lite since they are better reviewed.
- SoundPEATS Air4 Lite: https://www.amazon.com/SoundPEATS-Air4-Lite-Hiarkio/dp/B0C7G5MC2Y/
- Sudio N2: https://www.amazon.com/Sudio-Wireless-Bluetooth-Open-Ear-Earbuds/dp/B0BKGZJZT2/?th=1
I will also add the Soundcore K20i to the list.
https://www.amazon.com/Soundcore-Bluetooth-Wireless-Playtime-Comfortable/dp/B0D22RLPP3/
This is a pretty good roundup of outer earbuds for future recommendations.
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
Thank you for your addition. The Soundcore K20i doesn't have multipoint, but for someone who doesn't need it they're probably great. 🙂
