Will a liquid cooler work in my PC?
intelamdallthemisnice
Hi, my PC is quite new, so I don't want to swap parts. I found a few watercoolers for my Ryzen 5 4500 with a 65W TDP. I also found a Cooler Master Hyper 212 ARGB. I use a MSI A520M A-PRO in an ATX chassis.
Which cooler is best, The watercooler im looking at is MSI CORELIQUID M240. I have the worst stock AMD cooler? Which one is best, I play Fortnite and PCBS.
stop looking plz, its trash. look at any other cooler master AIO or maybe get a cheap arctic AIO if u rly want an AIO
Dont "watercool" a 4500 lol
Anything would be better than the stock cooler.
You will see no benefit at all going with a liquid cooler in regards to performance.
I found a Deepcool AG400 Digital Plus, is it good and should i get it instead? I dont have a 3pin ARGB header.
58 minutes ago, intelamdallthemisnice said:
I think I'll go with the Hyper 212, RGB and definetly better than the stock cooler!
On a Ryzern 4500, the stock cooler is more then fine.  That CPU is entry level and won't need anything more.
If you want something else, while technically "better", they're not going to do anything performance-wise for you.
Onyx AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
DIL: Ryzen 7800X3D - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 CL6000CL32 32GB - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
GF Rig: Steam Deck 512GB OLED
OnePlus Ecosystem:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
