PC will not turn on with gpu connected
Solved by Cheesebaron,
Do you have the possibility to test the GPU in another machine? Perhaps you have a friend or relative that has a PC where it could work in. That would help ruling out if that is the issue.
If not the GPU, check power supply and cables.
Did you update the BIOS before or after the issue started occurring?
Featured Topics
Sarath0508 ·
Posted in General Discussion6 -
tycho513 ·
Posted in Build Logs0 -
3
1
Zerlargal ·
Posted in General Discussion1 -
2
SS451 ·
Posted in General Discussion10 -
play_circle_filled
Latest From Linus Tech Tips:
Are You All Geniuses or Idiots? - Reacting to Your Best Tech MacGyvering
play_circle_filled
Latest From Tech Quickie:
Windows Used to Sell a Cheap Version. Here's Why They Stopped
play_circle_filled
Latest From ShortCircuit:
This time iPhone users are missing out - Google Pixel Buds Pro 2
play_circle_filled
Latest From Mac Address:
I found the CHEAPEST new Macbook. Is it better than a PC?
