Why are OLEDs dirt cheap when compared to LED monitors?
Readying myself up for the 4K future I'll be upgrading to so I'm researching the market. Still torn on the choices as looking at comparisons online, the mini LED monitors have such high peak all screen brigtness, in some games and movies the OLED's seem pretty washed out.
Problem where the fight does not come close is when I start looking at prices. Current year OLED's go around £1.2k-£1.4k which seems quite cheap when compared against £1.7k-£4k prices of mini LED monitors I'm seeing on PC hardware sites. These LED monitors aren't gonna be 2-3x better from the asking price.
Why? Isn't the OLED technology meant to be the new expensive kid on the block? Yet it's the cheapest one here... Make it make sense please.
For reference top tier OLED £1.2k LG 32GS95UE-B vs top tier LED £3.5k ASUS PG32UQX. That Asus isn't 3 times as good now is it, right?
Desktop: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - RMx 750 W 80+ Gold - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro Corsair K70 LUX browns - PC38X - Mackie CR5X's
Current build on PCPartPicker
The problem with OLED tech is that they suffer from burn-in and I don't believe that will ever be remedied. They are just trying to offload lemons at this point I believe.
If I was spending that many dollars, I would be trying to get an NVIDA "BFGD", IMO. They can't be matched, from what I can tell through reviews.
So you're saying the MSRP of £1.2k is actually just a short term disguised discount?
Basically.
They know they have a short life expectancy (1-2 years before issues ensue). They probably would honor the RMAs, but that's only a band-aid to that type of ouroboros. 🫤
That LCD monitor you listed seems pretty old now(2021 reviews), where as the OLED model seems to be from 2024. The LCD display also seems to sell for well under that MSRP in the US(IDK about UK though).
Ive used a good amount of oled displays and don't really see the washed out problem. Maybe cause I'm in a fairly dark room though. HDR is designed to scale pretty well to max screen brightness. I'd say oled brightness is more than fine unless your in a high ambient area.
Those many backlight LCDs still have some of the LCD issues like the higher pixel update speeds compared to OLED displays, and the ghosting near the bright highlights.
3 minutes ago, SpecTre12345 said:
Basically.
Really depends on use case, but Ive seen way longer than this on the OLEDs Ive used.
i basically have a uqx, a c2, and a dwf, so i can answer some of those questions. I'll try to go through each monitor as concise as possible.
IMHO, pick the monitor with cons u can stomach the most, none of them are perfect
burn in fears are overblown (haven't seen any), and if it's cheap, just get a new one in 3-4 years.
The updated version is the uqxr (hdmi 2.1 port) and without gsync,  which is 1k usd, dunno what it is in euros, you do not want a gsync module in ur monitor anyway, they are hot and will break ur monitor along with it.
https://www.amazon.com/s?k=pg32uqxr&crid=SJW2O5IJB9VT&sprefix=pg32uqx%2Caps%2C133&ref=nb_sb_noss_1
a budget version of this is the 32m2v for 500usd, slightly less color gamut and tuning overall, also available in 27inch
https://www.amazon.com/s?k=32m2v&crid=DNBP8WT7REPT&sprefix=32m2v%2Caps%2C161&ref=nb_sb_noss_1
pros
it has way better colors than the c2 and slightly better color than the dwf, can only tell side by side. Higher peak brightness (which i personally don't care about)
cons
blooming due to mini-led, grays are awful, really slow response time to the point where it's really only a 120hz monitor rather than 144hz.
For QD-OLED, i recommend the 321upx, make sure it's glossy if u can black out the room
https://www.amazon.com/s?k=321upx&crid=3FGXZXTTQ0ASZ&sprefix=321upx%2Caps%2C136&ref=nb_sb_noss_1
better response time vs mini-led, better colors against woled, but there's a purple tint if u can notice it.
For WOLED i'd go with the pg32ucdp*, or any model you can find cheaper.
blacks are actually black unlike the other 2, scenes where most of the screen is dark is better too. color volume is bad (c2's bad now but i doubt it's improved much judging from reviews), proven burn-in track record.
I personally would not get woled anymore, but if u want true black and have a dark room, it's competitive. The greens are freaking awful on both my oleds compared to the mini-led.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
8 minutes ago, xg32 said:
For WOLED i'd go with the pg32ucdm
PG32UCDM is QD-OLED. PG32UCDP is WOLED. (annoyingly confusing to keep them all straight, I know)
Also @venomtail its helpful to note that there is OLED and LCD as two high level panel technologies. When you see "LED" its simply referring to the backlight type, but any LCD you buy today in the consumer space is using LED's for backlighting in some way. Cheap stuff and old stuff is edge lit, while the newer higher end stuff is using Mini-LED full array local dimming. You'd  have to go back 15+ years for LCD's that weren't LED backlit and instead used diffused CCFL tech.
As impressive as it is in *some* respects, only crazy people spend what they're asking for a PG32UQX in 2024.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2
Ryzen 7 5800x - XFX RX6600 - Asus STRIX B550i - 32GB DDR4-3200CL14 - Corsair SF750 - Lian Li O11 Mini - EK 360 AIO - Asus PG348Q
I've been using this technology with cellular phones for many years, personally I don't trust it. But if you have observed otherwise, great for you!
Have you had burn in issues with phones? Ive over all been pretty happy with my OLED phones(mostly iPhones) and its great to have video with no grey bars when watching.
Every phone I ever had that used this tech had so many burn in issues, to the point where I had to replace the phone.
Gotta be a use case thing. I've never seen burn in on a phone. I'm also at 7000 hours on my LG C2 as a desktop monitor and don't have a hint of it.
Weird that an older model slipped through, filtered 2024 models.
I was referencing a guy playing racket and clank and in the open world scenes, they weren't close. The OLED couldn't keep up with all screen brightness.
Yea, the comparisons aren't as easy as they should be cause they all get compared in the best light, to the point where I can't tell how far disingenuous many comparisons are.
Basically OLED is great for something like Dead Space but a struggle with something like Horizon Forbidden West.
pros
cons
I'm hearing WOLED is the best of them all, at least in a PC setting.
Saying that the ASUS mini led is overpriced? If it was in line with the competition when it comes to the price I could consider it but yea, x3 is just a bit too much.
2/3 of my phone's that have OLED screen's have burn in. The one that hasn't is still new enough but long term performance will have to be seen.
But you can't really compare phones vs TV's and monitors, as heat is the main enemy. TV's and monitors get proper cooling whilst many phones get pushed to the limit where they throttle and overheat thus further harming the OLED cells.
Well OLED is better. Depends also which models you are comparing. But Mini LED monitors were always a bridge gap to OLED but also very expensive on top and worse. I always saw them as waste.
| Ryzen 7 7800X3D | AM5 B650 Aorus Elite AX | G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | Sapphire PULSE Radeon RX 7900 XTX | Samsung 990 PRO 1TB with heatsink | Arctic Liquid Freezer II 360 | Seasonic Focus GX-850 | Lian Li Lanccool III | Mousepad: Skypad 3.0 XL / Zowie GTF-X | Mouse: Vaxee XE wired | Keyboard: Ducky One 3 TKL (Cherry MX-Speed-Silver)Beyerdynamic MMX 300 (2nd Gen) | Acer XV272U | OS: Windows 11 |
i wouldn't use an woled for pc cause of static images and just how bad some colors look, so i'd rather use a qd-oled with the purple tint, it's not as noticeable as the blooming on miniled at least.
Yet to try an OLED monitor but reading reviews and comments I get the impression that everyone says QDOLED is the worst cause it has the worst black levels compared to other 2 OLEDs and that WOLED will last the longest and is the brightest so it can actually display a proper HDR image where as the others only excel at small area peak brigtness and constrast, simply taking advantage of itself being an OLED type panel.
there are multiple threads but this one has alot of discussion, u can check the sub further if u want, it's really interesting
if the color volume (the amount of color the tv is capable of displaying) is really bad, then is it really a proper hdr image, or have the people that still say WOLED is better never owned a QD-OLED before? WOLED only displays proper colors when the image brightness is low, Most of the people that own both leans QD-OLED. I'm not kidding when i say the colors are bad.
this is the color gamut of the newest woled monitor from LG, and thats with full color volume on low brightness. how they charge a premium is beyond me.
As for HDR, on a low brightness image, i'd take the WOLED on p3, for everything else p3 i'd go with QD-OLED, i force rec 2020 on my miniled in games like cyberpunk and dead space, neither oled is capable of forcing rec2020. Which also looks better on auto hdr.
These $4000 MiniLED monitors are from several years ago when OLEDs weren't around. More current MiniLED monitors capable of HDR1400 tiers of brightness sell well under $1000, often similarly priced or less expensive than similar specced OLEDs.
As someone who completely switched over to OLED 2 years ago, I still don't regret it. I'll adress a few of it's major discussing points:
- The picture quality is just better. Brightness might not be as high as the best MiniLED panels, but still high enough to deliver a good HDR experience combined with pixel-level dimming and true blacks. Call me crazy, but I think MiniLED HDR is much more uncomfortable to use. Having 600-1000 nits of fullscreen brightness will result in some very uncomfortable scenes. 150-250 nits of fullscreen brightness is much more useable. The <10% peak brightness is much, much more important for a good HDR experience in most scenes. And in this regard, OLED isn't too much behind. I'd say anything that can do >600 nits on a 10% window is bright enough to deliver a great HDR experience.
- Response times are so much better and since OLEDs don't need pixel overdrive, there is no overshoot and response time performance is the same at every refresh rate, be it at 480Hz or 60Hz. With many LCDs you need to use different overdrive settings at different refresh rates because the higher overdrive settings usually have way too much overshoot at low refresh rates. And only very few LCD monitors have automatic variable overdrive.
- Burn-in is way overblown. If you work on your monitor for 8 hours a day, every day, then I expect you'll run into it in a year or two. But if you use it as a content consumption and gaming monitor, with some occational web browsing or work from home, then I don't expect any issues in at least 3-4 years. And even if there is slight burn-in in 4+ years, that doesn't instantly make the monitor unuseable. You might only see it in certain conditions and it won't bother you for another few years before it gets too noticeable. Basically, in the time you'll run into burn-in, you're just as likely to have issues on a  MiniLED monitor. When talking about OLED burn-in, people tend to forget that LED backlit monitors aren't indesctructible either. Especially MiniLED has hundreds or thousands of LED's on the backlight which can also die over time.
I also have one OLED TV that has been exclusively used as a living room TV for almost 5 years now, and it also doesn't have any signs of burn-in yet.
- Text clarity isn't an issue in my case. I use 150% scaling on my 4K OLED monitor and don't have any issues with text. If anything, the glossy display coating more than makes up for the slightly worse text clarity because glossy is just clearer than matte to begin with. The 32" 4K monitors have high enough pixel density to completely counteract the text clarity issues, even at 100% scaling.
- The VRR flickering that came up in the last year or so isn't an exclusive issue with OLED. MiniLED is often even worse in this regard, but somehow people also tend to ignore this whel trash talking OLED monitors. And in the last 2 years I've been using an OLED monitor, I can say that this is a non-issue imo. You'll only notice it during loading screens. Normal gameplay never has these huge fps fluctuations you'd need to bring this flickering out, at least as long as your PC is capable of delivering decent performance to begin with.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
About the release dates, you're right. Some posts and articles and databases I used are severely out of date and I've interpreted the ASUS model as the new one instead it simply being the last one to be updated on said lists.
With the brightness you're right. Since I've never daily driven an HDR monitor and my only real experience with a near 10 year old Toshiba HDR10 TV. I think people underestimate how punchy a bright image is on TV's, but for such close up monitors... maybe you're right and it's not a great thing.
Everyone here's really turntabled by outlook on the QDOLED panels. But yea, £1.2k seems like an average price for a new panel.
Here in Germany the 32" 4K OLED monitors start just above 900€.
The 27" 1440p OLED monitors start around 600€.
I got my 42" 4K LG C2 for 1.050€ 2 years ago. But these LG 42" TVs have been selling for around $800 at times, which is just insane value for this display size and OLED.
When you want a comparable MiniLED monitor to the $4000 MSRP Asus model, the Samsung Odyssey Neo G7 can be had for around 650€.
So yeah, the introduction of OLEDs on the display market significantly changed prices.
54 minutes ago, Stahlmann said:
Here in Germany the 32" 4K OLED monitors start just above $900.
The 27" 1440p OLED monitors start around $600€.
When you want a comparable MiniLED monitor to the $4000 Asus model, the Samsung Odyssey Neo G7 can be had for around $650.
Yea, on PCPP the absolute cheapest starts around 1300eur and 1440p starting around 800eur. Quite the bump. Is this another Brexit benefit? I was considering a 27 1440p OLED but if I realistically want to get a single monitor for the next 15 years, I think 4K leaves plenty more room to grow.
Idk about post-brexit shipping rates to the UK, but it might be cheaper for you to buy in Germany and ship it over there 😄
When just converting €/£, the 32" model should be around £760 if it would be selling for the same price. That's quite the leap.
