Hello everyone. I need your help regarding a sound card.
I am using the Asus ROG B650E-E model and I am not happy with the sound at all. It causes cracking in the sound especially in high basses. I tried different speakers but the result did not change at all. I have heard that there are many people who are using Realtek alc4080 and are not happy with this audio codec.
My previous motherboard was the ROG Crosshair X570. And it was much better in terms of sound.
Now, coming to my question, I want to buy a sound card.
Frankly, I do not have a very high-end sound system. But I want to buy a sound card that I can get quality sound with 2+1 or 5+1 systems for many years to come. I can choose the models I have shared below in the stocks of the country I am in.
Which one do you think I should buy?
Note: I do not want to buy a DAC because I do not want it to take up extra space.
Asus XONAR AE 7.1
Asus XONAR SE
Creative Audigy FX V2
Creative Sound Blaster RX
AMD RYZEN 9 7900X3D | Gainward GeForce RTX™ 5070Ti Phoenix | ASUS ROG CROSSHAIR X670E HERO | ASUS ROG STRIX LC III 360 ARGB | G.SKILL TridentZ5 NEO RGB 2X24GB 6400Mhz CL32 RAM | Asus ROG Strix SCOPE | Asus ROG STRIX Impact III | XPG SX8200PRO 2x2TB nVME | XPG SX8100 3x2TB nVME | Seagate Barracuda 2x5TB HDD | Corsair RM1000X Shift 80+ Gold | Corsair 7000X Case
Asus XONAR AE 7.1
Asus XONAR SE
The Xonar SE uses a Realtek chip, an ALC 1220, or similar, so it should be the closest to your previous sound.
The Xonar AE is probably the best, especially for headphones. It uses roughly the same DAC components as modern $50-$100 USB-C DAC-s.
But, have you tried using IOBit Driver booster to update your Realtek drivers?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
They published a patch on my motherboard's web page, but it's only a patch for the Digital output. The same problem occurs with analog. Especially in high-decibel sound ranges, i.e. intense bass or sounds, there are cracks. This happens when playing AOE4 and in some games. This new sound chip uses the USB interface. The old ALC1220 used a pcie interface. That's why I was not satisfied with the ALC4080 at all.
I updated it with the IOBit driver, but the result did not change. I tried everything.
What if I choose Xonar AE instead of Xonar SE? I hope these models do not have Windows 11 driver problems?
Are you using powered speakers or is it running thorugh an amp?
I am using Creative 2+1 Inspire T3300. But I have tried with other brands including Logitech and the result is the same.
If you are using powered speakers, then get a DAC like the apple dongle or the moondrop dawn pro. They are small, usb powered and will be more that enough for what you need.
A soundcard is typically a DAC+amplifier+whatever extra stuff the manufacturer throws in.
Buying a soundcard is pointless unless you own powered speakers that require 5.1 outputs. And I would not waste money and space on a 5.1 system when you can just use the extra money on a better 2.1 system..
Just like @Blue4130 said, buy the $9 Apple USB-C dongle, check your local online retailers and search "CX31993", or look up any of the many USB DACs available online (like the Moondrop Dawn Pro).
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
