HOW TO CONFIGURE ASUS HYPER M.2 CARD WITH ASROCK AB350 PRO4 MOBO
Go to solution Solved by Electronics Wizardy,
1 minute ago, WarsawWarrior said:
I have it in the second x16 slot since my gpu is in the first x16 and I wouldn't want to lose gpu performance. Does this mean it can only be used with one m.2 drive if I use that second x16 slot?
The second x16 slot is actually a x4 slot. So you can only use one ssd with that slot. You need to use the top slot to use all 4 m.2 drives on there.
I bought an Asus hyper m.2 card hoping to add some m.2 slots and add more storage. I have 3 m.2 drives installed, but only one shows up. I am using an ASRock board so I wasn't sure if this could create any configuration headaches. I was looking for a bifurcation setting in BIOS and saw this in the picture below. Will this setting effect my GPU x16 slot? How do I configure this properly?
IMG_8747.HEIC
What slot is the card in? You need that 4 m.2 slot in the top card to use all 4 ports, and that means you have to run your GPU from the chipset, hurting performance a good amount.
Those 4 m.2 cards aren't really made for am4/am5/1700 and don't really make sense for most uses.
Bummer, thanks for the help though!
That mobo is so bad ( that’s why I hate AM4 )
you have only one M.2 slot PCIe 3.0 x4
and if you use it it’s disables the PCIe4 ( as they share lanes )
second M.2 slot is only a sata ahci slot
so you are left with 4 slots of PCIe 2.0 x1  ( around 350-380MBps max speed )
They are usable to run M.2 NVMe SSD, but sequential speeds are bad
if 350MBps is enough for you for storage etc, you can use them
you need a PCIe x1 to M.2 adapters (like this verticale one https://www.amazon.com/Sintech-NGFF-PCIe-Adapter-Samsung/dp/B07F1J7S3F )
( and you can use all the ports that aren't covered with gpu ( so 3 or 4 slots, depending how big your GPU is )
CPU : Intel 14gen i7-14700K
COOLER :  Thermalright Peerless Assassin 120 White + thermaltake toughfan 12 white + Thermal Grizzly - CPU Contact Frame Intel 13./14. +  Coollaboratory Liquid Ultra
GPU : MSI RTX 2070 Armor @GPU 2050MHz Mem 8200MHz -> USB C 10Gb/s cable 2m -> Unitek 4x USB HUB 10 Gb/s (Y-HB08003)
MOBO : MSI MEG Z690 UNIFY
RAM :  Corsair VENGEANCE DDR5 RAM 64 GB (2 x 32 GB) 6400 MHz CL32 (CMK64GX5M2B6400C32)
SSD : Intel Optane 905P 960GB U.2 (OS) + 2 x WD SN850X 4TB + 2 x PNY CS3140 2TB + ASM2824 PCIe switch -> 4 x Plextor M8PeG 1TB + flexiDOCK MB014SP-B -> Crucial MX500 2TB + GoodRam Iridium PRO 960GB + Samsung 850 Pro 512GB
HDD : WD White 18TB WD180EDFZ + SATA port multiplier adp6st0-j05 (JMB575) ->  WD Gold 8TB WD8002FRYZ + WD Gold 4TB WD4002FYYZ + WD Red PRO 4TB WD4001FFSX + WD Green 2TB WD20EARS
EXTERNAL
HDD/SSD :
XT-XINTE LM906 (JMS583) -> Plextor M8PeG 1TB + WD My Passport slim 1TB + LaCie Porsche Design Mobile Drive 1TB USB-C + Zalman ZM-VE350 -> Goodram IRDM PRO 240GB
PSU :  Super Flower leadex platinum 750 W biały -> Bitfenix alchemy extensions białe/białe + AsiaHorse 16AWG White
UPS :  CyberPower CP1500EPFCLCD -> Brennenstuhl primera-line 8 -> Brennenstuhl primera-line 10
LCD :  LG 32UD59-B + LG flatron IPS236 -> Silverstone SST-ARM11BC
CASE :  Fractal R5 Biały + Lian Li BZ-H06A srebrny + 6 x Thermaltake toughfan 14 white + Thermalright TL-B8W
SPEAKERS :  Aune S6 Pro -> Topping PA3-B -> Polk S20e black -> Monoprice stand 16250
HEADPHONES :  TOSLINK 2m -> Aune S6 Pro -> 2 x Monoprice Premier 1.8m 16AWG 3-pin XLR -> Monoprice Monolith THX AAA 887 -> 4-pin XLR na 2 x 3.5mm 16 cores OCC 2m Cable -> HiFiMAN Edition XS -> sheepskin pads + 4-pin XLR na 2 x 2.5mm ABLET silver 2m  Cable -> Monoprice Monolith M1060 + Brainwavz HM100 -> Brainwavz sheepskin oval pads + Wooden double Ɪ Stand + Audio-Technica ATH-MSR7BK -> sheepskin pads + Multibrackets MB1893 + Sennheiser Momentum 3 +  Philips Fidelio X2HR/00 + JBL J88 White
MIC :  Tonor TC30 -> Mozos SB38
KEYBOARD : Corsair STRAFE RGB Cherry MX Silent (EU) + Glorious PC Gaming Race Stealth Slim - Full Size Black + PQI MyLockey
MOUSE :  Logitech MX ERGO + 2 x Logitech MX Performance + Logitech G Pro wireless + Logitech G Pro Gaming -> Hotline Games 2.0 Plus + Corsair MM500 3xl + Corsair MM300 Extended + Razer goliathus control
CONTROLLERS :  Microsoft xbox series x controller pc (1VA-00002) -> brainwavz audio Controller Holder UGC2 + Microsoft xbox 360 wireless black + Ravcore Javelin
NET :  Intel x520-DA2 -> 2 x FTLX8571D3BCV-IT + 2 x ASUS ZenWiFi Pro XT12
NAS :  Qnap TS-932X-2G -> Noctua NF-P14s redux 1200 PWM -> Kingston 16GB 2400Mhz CL14 (HX424S14IB/16) -> 9 x Crucial MX500 2TB ->  2 x FTLX8571D3BCV-IT -> 2 x Digitus (DK-HD2533-05/3)
Only other option is to buy a pcie switch and use it in PCIe4 slot ( but it’s like 180$ ), you would have all you m.2 ssd nvme in it ( as m.2_1 would be disabled.
https://www.amazon.com/GLOTRENDS-PA40-Adapter-Bifurcation-Function/dp/B0CCNL7YD8
EXTERNAL
HDD/SSD :
Thanks for the info! I bought the ASUS hyper off eBay for cheap so not too heart broken about it. I bought it in the first place too because both my m.2 slots were killed by a faulty HP m.2 drive years ago. I work at a repair shop and maybe could fix the slots if its just a blown cap near the slots, but felt like too much effort for my own computer and time lol
well, you can use it, to check if the pcie4 is ok ( just use some sacrificial m.2 ssd nvme ), as pne ssd in first slot should be working
EXTERNAL
HDD/SSD :
