RTX4060 8gb vs RTX3060 12gb for 4k
Psittac
An online buddy of mine that I talk to every day is on a fixed income and his PC is rather old and causes him anxiety about the idea of it dying.
I have been trying to figure out the most cost effective way to get him an upgraded system before his poops out and watching scrap yard wars I figured I would check out jawa again, now I'm pondering getting him a piece at a time until he has a completely new to him system.
They have a 3060 12g but bestbuy has a new 4060 for $60usd more.  All thing's equal what would be a better option for him?  I'm thinking of an AM4 system in the long run with 32gb of ram and he runs on a 4k TV probably at 60hz
Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100 - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
That's not really a cost effective way to go about it. Why replace parts before they're actually dead. Depending on how long into the future that is, you can probably get a better deal at that time (same hardware for less or newer hardware for the same)
How much does $60 mean in %? The 4060 has roughly 20% better performance.
That said, neither is particularly great for 4K and a lack of VRAM on the 4060 isn't particularly good for longevity either. Unless your friend needs the best RT or CUDA, I'd also take AMD cards into consideration, since they're usually better in terms of perf/$
Arguably the 4060 is the worse card despite having more raw performance.
It's very limited by it's 8GB of VRAM, it's bus width and it's PCIe lanes (if used on older system with just PCIe 3.0).
Well the thing is that my money comes in randomly, it's easier for me to afford several small purchases rather than one large purchase.  Also, even though we have each others information I'd rather avoid him being without his PC for any amount of time.  So if we can avoid down time that is worth a hit to performance and/or cost.
20+ years ago all I had was my computer, in many ways.  If it broke I would spaz and freak out and cobble together components I had so I could at least get online while I waited for newegg to somehow replace my mb yet again.  While he has a far more varied life than I did back then, I can relate to the woes of losing your connection with basically everything.  Fuhq a phone, PC only.
Also I have a bare bones Alienware that I might send to him if the shipping isn't too bad, at least less than a case/mb/psu/hsf.
I'm contemplating getting him some ram to match his PC now so he has 32gb now and will hopefully run on the Dell frame.
DAC S.M.S.L SU-9
Any time you can afford a part, put the money you would have spent to the side and consider it spent. It'll add up and at some point you can afford one large purchase. At least that's what I would do.
Doesn't work unfortunately, I've tried in the past.  I'm far to impulsive and would buy something for my car or headphones or something else useless
DAC S.M.S.L SU-9
  • 2 weeks later...
21 hours ago, Shloopingle said:
Neither at 4K...
Just upscale from 1440p with DLSS in games that need it.
Some games is easy to run.
But yeah, do not buy GPU with 8GB VRAM, it's too little.
“Remember to look up at the stars and not down at your feet. Try to make sense of what you see and wonder about what makes the universe exist. Be curious. And however difficult life may seem, there is always something you can do and succeed at.
It matters that you don't just give up.”
-Stephen Hawking
On 8/27/2024 at 4:07 AM, Shloopingle said:
Neither at 4K...
well.... He's running a 1660 right now so no matter what it'll be an upgrade
DAC S.M.S.L SU-9
On 8/27/2024 at 6:07 AM, Shloopingle said:
Neither at 4K...
I run my 3060 12GB at 4k Semi regularly. Its mostly older games, but once in a while a new one like RE4R
3 minutes ago, Shloopingle said:
Avoiding FSR or using a lower res than native is always the best, unless you like very parred back visuals, saying that it's not as if games can't look good on close to lowest settings.
.... sorry I should have said, at max or near max settings.
RE4R I used DLSS on yes.
Like I can play Mass effect enhanced maxed out on it.
2 minutes ago, Shloopingle said:
I agree until you try playing something like Remnant 2 or anything that basically has a PS5 / XBOX ONE X exclusive release and is not made for XBONE or PS4, it all goes to crap.
cool then you can play at 1440p and run dlss.
the 4060 8GB may get better fps at 4k (and 1440p) in games that use less then 8gb of ram, but games that use 10GB like ps5/xbox one X ports. dont run better on the 4060.
I personally would not buy EITHER card today. I would get an AMD card if buying today, or wait for blackwell in Q1 2025
17 minutes ago, Shloopingle said:
So you buy a 1440P screen, not 4K.
This is why I originally said neither at 4K.
The TV is 4k. my main screen is 1440p
OP is talking about playing the odd game on the 4k TV. We are not talking about the main monitor.
no one buys a 1440p TV.
3 hours ago, Shloopingle said:
We are not here to discuss your monitors and TV's, you directly quoted me because I said not 4K with either of them, I have explained to you why as the only information the OP gave was 4K.
The 3060 and 4060 are too weak regardless of memory config.
I don't know about that game, but I would turn down settings from ultra to high to play at higher resolution (at the same FPS), if I need to, any day of the week.
And I don't think you should make decisions on what monitor to use on the worst case scenario game.
We also don't know for sure what games OP is going to play.
And you can use upscaling like DLSS.
-Stephen Hawking
I actually have both, the 3060 12G in my old desktop, and a laptop 4060 (basically the same as the desktop card, just slightly slower clocks and more L2) in a machine I picked up on a really sweet discount.
The RTX 4060 certainly is more performant, and it’s quite efficient (more appreciable in a laptop), but all the performance and efficiency in the world is worthless once that 8 GB VRAM is hit.
Both cards are not well suited to native 4K in modern titles, though I frequently play older games at 1440P and 4K. Devil May Cry 5 does net 4K 60 fps on the 4060. Spyro Reignited falls ever so slightly short at 4K. Final Fantasy XII runs beautifully at 4K. If I’m willing to take the fan noise, I can even push 4x MSAA and Full Precision AO, which the desktop 3060 could not do.
Cyberpunk 2077, native 1080P with optimized settings (no RT) has me at between 80-100 fps. Looks fine enough upscaled to 4K. I often run frame gen on the laptop (when gaming on the internal panel) to allow the fans to run a bit slower, while still hitting the 144 hz cap pretty solidly.
Running RT though, does push things a bit over the limit. On the internal panel, I can do RT Lighting on Medium, and still get solid performance at native 1200P. Adding reflections does drop me down pretty harshly, 30s or so, requiring DLSS Quality to claw back performance.
Connected to my 4K tv is where that VRAM really hurts. With my optimized raster settings plus above RT effects, with DLSS at Ultra Performance (720P render res), the stuttering is pretty lousy.
As for the 3060, if your target framerate is 60 fps, probably best to pretend RT doesn’t exist (30 fps is probably doable). It’s excellent for Blender (rendering via Optix is amazing), but not really fast enough to be useful for gaming.
And the 4060 is a decent enough laptop GPU, if the price is right, but pretty lackluster for desktop, where the efficiency doesn’t do much for it.
My eyes see the past…
My camera lens sees the present…
I almost love how this has become a biker fest between the (more than likely) regulars from this sub-forum.  I spend most of my time on the audio sub-section and while some people have wildly different concepts and obvious bias, I've learned to make peace with them and accept their opinions.  Though sound is far more subjective imo than visual.  There are legitimate actual numbers you can put on GPU's because it's purely math.  While there is subjectivity to a point given all the variables, someone could conceivably test every parameter with repeatable numbers.
He doesn't play much for demanding titles other than Diablo 4.  It's valheim and Eve Online right now with some forays into various low demanding games.  I think that DLSS is a great idea.
As for eye candy vs resolution I figure he can decide when he gets the hardware.
Thank you for the first hand comparison.  My take away is that he should take it on a case by case basis, ignore RT or keep it low and if he wants to run native 4k the 12gb is important.  I think I'll get the 3060, however by the time I get some bills paid down I might be looking at a different market.
Most of this is pre-emptive to avoid his system borking and being cut off from the world, and at worst have two systems to rely on.
DAC S.M.S.L SU-9
