My pc motherboard broke so I am building a new pc with parts from the old pc (cpu,ram,ssd) All I need is a good motherboard that will not die on me.
Budget (including currency): any thing that is not too expensive (usd for currency)
Country: USA
Games, programs or workloads that it will be used for: Roblox, Minecraft, Farming sim 22, Nascar heat 5, and any more games that come out in the future
Other details The parts are not 100% accurate but I did the best I could. For example the cpu cooler is not accurate I will reuse the cpu cooler.
Pc Part picker: https://pcpartpicker.com/list/WhVvPF
MSI MAG B460 Tomahawk.
If a post resolved/answered your question, please consider marking it as the solution. If multiple answers solved your question, mark the best one as answer.
Country: USA
If you don't care about supporting the case front panel USB-C port, https://pcpartpicker.com/product/CtbCmG/asrock-b460m-pro4-micro-atx-lga1200-motherboard-b460m-pro4. Otherwise https://pcpartpicker.com/product/RfBhP6/msi-mag-b460-torpedo-atx-lga1200-motherboard-mag-b460-torpedo.
What is old and what is planning to be bought?
current PC:
Ryzen 5 5600 |16GB DDR4 3200Mhz | B450 | GTX 1080 ti
PCs I used before:
Country: USA
What happened to your board? They don't usually break out of the blue...
And really pls give a budget, "not expensive" don't mean anything
I went to turn on my pc and it did not turn on I did lots of trouble shooting like psu jump start and using another psu that was previously in the pc. My budget would be around 350-400 usd
What's telling you it's not the CPU or RAM ?
I need a new motherboard for my pc. I am upgrading to a bigger case so I will be reusing parts from my old pc.
There is a rgb strip in the back of the case it shows that their is power in the pc. That light has not turned on since the incident
The PC has 0 power, and same with another working PSU ?
Yes
so you have H6 NZXT case?
and the RTX 3070?
you seem to already have good enough parts, just a new MB would suffice honestly.
if the other parts aren't somehow in fault, and perhaps an attempt at RAM OC would even leave buying faster RAM out of question
current PC:
PCs I used before:
Yes
Ok, then the board looks like it died
I won't invest in a new 10th gen board, it's old tech now
With $400 you can get this
PCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($181.95 @ Amazon)
Motherboard: Gigabyte B650M D3HP AX Micro ATX AM5 Motherboard  ($129.99 @ Amazon)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  ($89.97 @ Amazon)
Total: $401.91
Generated by PCPartPicker 2024-08-11 16:29 EDT-0400
and the RTX 3070?
I have the 3070 but I will be buying the H6 as part of this upgrade.
Total: $401.91
why not keep 8 core 5GHz boost CPU that on top of that doesn't suffer from mild latency issues like the newer Intel do?
I don't see a reason of paying extra just to arrive at similar performance, a much more powerful upgrade could happen later, with potentially lower DDR5 prices, etc.
check out other cases,
especially from Montech, Phanteks, Lian Li, Corsair, or NZXT
current PC:
PCs I used before:
oh ok
Just now, MingoGamer5137 said:
oh ok
not saying H6 is bad, if you like it go ahead, it's good
current PC:
PCs I used before:
The clock itself don't tell the whole story, a 7600 is around 15-20% faster in games and productivity, because of the newer architecture, better IPC, DDR5 RAM...
And the 10700 has 0 upgrade path...
Sure it's still a decent CPU, but it's 4 years old now, good time for OP to move on ! 🙂
if they have budget sure,
but buying MB and case isn't expensive and their parts are good already
current PC:
PCs I used before:
