Build help
Budget (including currency): $1200 AUD build
Country: Australia
Games, programs or workloads that it will be used for: Minecraft, cs2 valorant spiderman miles morales
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): 180hz i need an 8 core cpu
https://pcpartpicker.com/list/QRMY34
This is what I came up with. Note that at this price point there is no way that you are hitting 180fps in miles morales, at 1080p high without DLSS you should be in the 85-90 fps range.
uhh i live in australia
Tried to use the max of your budget. As mentioned, you are not hitting 180 fps in everything at this budget. If you bought your GPU used you might be able to do much better or if you saved about $250 more you can get around 7700 XT new or 6800 used.
PCPartPicker Part List: https://au.pcpartpicker.com/list/DqQ2Xk
CPU: AMD Ryzen 7 5700X3D 3 GHz 8-Core Processor  ($354.00 @ BPC Technology)
CPU Cooler: Jonsbo CR-1000 66.81 CFM CPU Cooler  ($25.00 @ PLE Computers)
Motherboard: ASRock B550M Pro4 Micro ATX AM4 Motherboard  ($129.00 @ Scorptec)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  ($104.00 @ I-Tech)
Storage: TEAMGROUP T-Force Cardea Z44L 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($89.00 @ Centre Com)
Video Card: Gigabyte GAMING OC Radeon RX 7600 8 GB Video Card  ($384.00 @ PLE Computers)
Case: Deepcool MACUBE 110 MicroATX Mini Tower Case  ($60.00 @ Scorptec)
Power Supply: Gigabyte UD750GM 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($114.77 @ JW Computers)
Total: $1259.77
Generated by PCPartPicker 2024-08-10 14:01 AEST+1000
Had to go X3D because if I'm building on AM4, then at least an X3D chip is a must for an 8-core requirement.
Total: $1259.77
fuck i forgot to mention i need wifi
PCPartPicker Part List: https://au.pcpartpicker.com/list/dKtY34
Motherboard: Asus PRIME B550M-A WIFI II Micro ATX AM4 Motherboard  ($147.77 @ JW Computers)
Total: $1278.54
Generated by PCPartPicker 2024-08-10 15:38 AEST+1000
