Gigabyte X570 Aorus Elite - Updating bios to anything newer than F37 not working
Go to solution Solved by Cheesebaron,
OK, some breakthrough!
Flashed a new vbios on my graphics card as it was running the F2. Gigabytes own tool doesn't seem to work so used nvflash. Need to flash the other bios too I guess, since I only flashed the silent side.
So ended up being the vbios not being compatible somehow.
I've tried previously as well updating the bios to F39, yesterday I tried F40, hoping that it would work, but it doesn't seem like it.
Checksum matches when looking in QFlash and the website.
After flashing the bios on the motherboard, it fans spin up, lights on the motherboard are on and after a short while graphics card fan spin down. However, CPU and chassis fans which use the motherboards fan headers are running at full power. I've tried leaving it like this for 10-15 minutes.
I've tried clearing CMOS before and after flashing the bios, I've tried booting it just with one stick of RAM and tried using a 5900X and 5700X3D. Using bios flashback, back to F36 or F37 makes the board boot again, but anything newer doesn't.
Any ideas what could be the cause? I'd like a newer bios because of the AGESA updates.
Maybe only thing I haven't tried is to flash the new bios using the bios flashback functionality on the board.
Was a CPU connected while flashing to F37? If not then reflash F37, then you should be able to flash F39 and then F40b
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Yes, CPU was connected in all attempts.
One thing I didn't mention I also tried flashing back F36 then updating to F39 and F40. That doesn't work either. F36 to F37 works.
Try removing all peripherals, including SATA. Clear CMOS and Flash F37 again. Nevermind use F30 as that is the first BIOS to support 5700x3d.
https://www.gigabyte.com/Motherboard/X570-AORUS-ELITE-rev-10/support#support-cpu
Interesting, I didn't think of that, will give it a go later today.
GL 🙂
Dual Bios is messing with you. You should use Gigabyte (at)bios @Bios to update the secondary Bios too.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
So it seems like F40b, boots but only when the Graphics Card is out of the machine. As soon as it is in then it doesn't boot.
I'll try flashing back F37 and use the @Bios to flash
EDIT:
Tried flashing F40b from @Bios and it doesn't seem to make any difference. Machine won't boot as long as the graphics card is in it. I don't have another graphics card to try with, so not sure what to do here.
Borrowed a GT710 and flashed F40b. Works fine with that card. But not with my 3090. F37 runs fine with the 3090. Not sure what is going on. Don't have enough space to try the 3090 in a different slot.
When it booted into F40b also looked like they added PBO options, which don't seem available on F37. Bummer.
