Need help upgrading prebuilt with serious CPU bottleneck
Budget (including currency): $1200
Country: United States
Games, programs or workloads that it will be used for: Switch Emulation, FF7R
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I have an HP Omen 880-130 that was given to me by a (very generous) friend a few years ago. I have since added some high-end upgrades, including an RTX 4090, PSU, and more RAM, but it's still rocking an i7-8700K. I know it's a bottleneck, but the mobo seems to not support other CPUs, at least based on what I've found online. I'm willing to replace the mobo, CPU, and RAM, but don't want to spend that kinda cash to find it's not compatible. It's apparently uATX, but I don't know if there is any proprietary nonsense happening. Any thoughts on a route I could go?
Buy a new case, then upgrade the mobo/cpu/RAM.
You can afford to buy a 4090, the rest of the machine is less than HALF that.  Pony up 🙂
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($366.83 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($36.90 @ Amazon)
Motherboard: Gigabyte B650 GAMING X AX ATX AM5 Motherboard  ($173.00 @ Amazon)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($100.98 @ Newegg)
Case: Fractal Design North ATX Mid Tower Case  ($109.99 @ Amazon)
Total: $787.70
Generated by PCPartPicker 2024-08-07 22:46 EDT-0400
Onyx AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
DIL: Ryzen 7800X3D - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 CL6000CL32 32GB - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
I 100% agree...
If you can't afford the rest, this is a good leason to be learned. The savings on buying a 4080 instead of a 4090 would have gotten you a full platform upgrade AND a 4080, which would almost certianly result in better performance in *almost* every game than a 4090 on a 8700k.
Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
7800X3D
Gigabyte B650 Elite or Gaming or Pro
G. Skill Flare X5 2x16GB 6000MHz CL30
All set.
I'm thinking that I might just go full send on the CPU and get a 7950X3D, the difference in price is less than $200 and the boost in performance seems to be substantial. All in I would be around $800, which I could live with.
If you are primarily gaming then the boost is iffy at best. Seems to be generally -2 to +2 fps at 4K on most games. For $200 that seems like a terrible deal.
https://www.techpowerup.com/review/amd-ryzen-7-7800x3d/21.html
If you primarily do rendering, then I can see it. But not for gaming...
There is no boost if just gaming.   Hopefully you meant something else.
I am concerned you don't fully understand PC components.
OnePlus:
Other Tech:
I understand PC components just fine, and I knew when I got the 4090 that it would be bottlenecked. In all honesty, I was planning to put it in an Alienware Aurora R13, but it didn't fit in the case (by the tiniest margin). It fit in this older gaming rig, but I knew I was leaving a ton of performance on the table. I want to correct that, and I can afford upgrades. I just want to get something that will work with the rest of the system without building a whole new rig.
Just now, NachoKingP said:
I understand PC components just fine, and I knew when I got the 4090 that it would be bottlenecked. In all honesty, I was planning to put it in an Alienware Aurora R13, but it didn't fit in the case. It fit in this older gaming rig, but I knew I was leaving a ton of performance on the table. I want to correct that, and I can afford upgrades. I just want to get something that will work with the rest of the system without building a whole new rig.
Right so what did you mean by the boost seems to be substantial?  The 7950x3d over the 7800x3d?
For gaming there is no benefit of the 7950x3d.
Either works with the rest of the system.   Just making sure you understand the 7950x3d is actually worse for gaming, but you get what you want.
I've relayed the facts. All I can do 👍
OnePlus:
Other Tech:
I don't just game on this, I also use it as my Plex server and do a lot of encoding on it when I rip blu-ray discs and sometimes light video editing.
Moving goal posts.
If you want valid suggestions, give us valid information at the start, not at the end of the discussion.
