Hi All! I am planning on getting starlink as I live in the middle of nowhere and TMobile has been really bad...
What is the best mesh wifi system to use with starlink? I have a network switch to several devices in my house but need a solid wifi solution. I think I will put the starlink modem in bridge mode. Roughly 4000sq ft house with 2 levels. Would also love to have Wifi outside in the backyard as well.
https://linustechtips.com/topic/1578684-best-mesh-wifi-for-starlink/
The source of your internet really doesn't have much impact on the performance of a wifi system. Thus, if you're dead set on mesh, I'd recommend reading up on general mesh recommendations
On the other hand, Is there any chance you would consider multi point wifi with hardline backhaul? If so, I can heartily recommend Ubiquiti, especially their LongRange AP which gets me >500Mbps at 200' through my garage wall
I wasnt specifically set on Mesh and was actually just looking at Ubiquiti set ups.
