Roblox freezing randomly, Unsure if it's a heat issue or not
After recently resetting my pc I reinstalled roblox and it suddenly started randomly freezing on almost all roblox games specifically. It's never done this before so I was confused and thought it may be an issue with my cooling since I didn't have the money to spend on a new cooler or PSU yet. I just want to figure out what the issue is other than just that it's a hot running cpu.
Specs:
CPU - Ryzen 7 5800x
Graphics card  - Nvidia 4060 RTX
PSU - CV 450
16gb RAM.
Cooler - Stock AM4 cooler (I need to get an upgrade but not sure which to get)
I'm taking a guess that it's either the lacking PSU or the cooling but otherwise not sure.
Temps run on about sub 40 to 50 idle and peaks at 90 ish during heavy loads.
(To add the gpu and cpu are new and I installed the cpu much later since it arrived late)
run furmark or some other gpu benchmark + prime95 smallest ffts both at the same time
if it shuts down replace psu otherwise might be running into instability, usually ram but could also be an overzealous overclock/undervolt or if its none of those id blame the board cause unexplainable behaviour = probably fucked board
Was roblox working before? Did you make sure to install and setup drivers after the reset?
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - ASUS TUF Gaming OC RTX 4090 RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - H150i Pro XT | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S24+ - Ceramic White 512GB |
Roblox did work before fine, I believe I did install things properly however it wasn't a full reset only a data reset. I installed all the new CPU and GPU drivers though. - adding to this now that I think about it today I saw some sort of graphics issue with my discord text so I'm guessing I forgot something..
I will look into this, I know the mobo is a little shitty, its an older asus model I can't check right now but it could defiantly use a new one.
Results after testing, gpu and cpu temps etc. After running prime95 for a little bit it lowered to about 65 to 75 percent usage
What are your CPU temps while playing roblox? If roblox was working fine before the reset it's gotta be a driver or software issue. Were you having problems before the reset, why did you reset it in the first place? Also why did you do just a data reset over fresh installing the OS?
There are temps and speeds while running a heavier built game. Also reset because I had a storage drive issue. I just reset the data so I could repair the drive.
I'd use HWInfo64 or HWMonitor to watch your temps. That appears to be NZXT Cam which I'm not much of a fan of for temperature monitoring. 40% load on the CPU and hitting 82c isn't ideal, though you are using a stock cooler. AFAIK the 5800X doesn't come with a stock cooler so did you purchase a stock AM4 cooler seperately?
