What command are you actually running? Is it a
netstat -a
If so then it will just list all connection that either your laptop/pc is reaching out to or sessions that your machine is listening out for. So something is trying to reach out to port 49350 and it's timing out.
Can you run a
netstat -b
This should show you an output with the apps that have created the sessions.
https://learn.microsoft.com/en-us/windows-server/administration/windows-commands/netstat
netstat -a
Can you run a
netstat -b
I ran netstat and also netstat -a. I think it might have been QueenCreek running
