compatibility and quality part review! firstbuild!
PCPartPicker Part List: https://pcpartpicker.com/list/TTZRDZ
i mainly use my pc for 3D modeling and rendering ,i will be working with blender and z brush
im about to buy this part and start building my first pc, but im not sure about some of them
i want to ask for
1. compatibility check
2. quality part check (whether the part is good or no, have any issue or no, and maybe some better recommendation, etc. etc.) PCPartPicker Part List: https://pcpartpicker.com/list/TTZRDZ
3.help me chose which cpu cooler and memory is better on bellow
CPU Cooler: Cooler Master Hyper 212 RGB Black Edition 59 CFM CPU Cooler  https://www.amazon.com/dp/B09KYC4Z98?tag=pcpapi-20&linkCode=ogi&th=1&psc=1
-----OR-----
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler     https://www.amazon.com/dp/B09LGY38L4?tag=pcpapi-20&linkCode=ogi&th=1
----------------HELP ME CHOSE THEY BOTH THE SAME PRICE IN MY COUNTRY--------------------
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30-40-40-96
-----OR------
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400 CL32-39-39-102
CPU: AMD Ryzen 5 7600X 4.7 GHz 6-Core Processor  ($197.78 @ Amazon)
Motherboard: ASRock B650M Pro RS WiFi Micro ATX AM5 Motherboard  ($149.99 @ Newegg)
Storage: Silicon Power US75 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($119.99 @ Amazon)
Video Card: Zotac GAMING AMP Spider-Man: Across the Spider-Verse GeForce RTX 4060 Ti 16 GB Video Card
(my version of vga is non spider man btw, i cant find the non spiderman AMP 16gb ver on pcpartpicker)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case  ($79.99 @ Adorama)
Power Supply: MSI MAG A650GL 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($76.00 @ Amazon)
Monitor: MSI PRO MP275Q 27.0" 2560 x 1440 100 Hz Monitor  ($159.99 @ Amazon)
Edited by rennatavoid666
Minor adjustments, but plenty for quality's sake:
CPU: *AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($193.38 @ Newegg)
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  ($35.90 @ Amazon)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  ($169.99 @ MSI)
Memory: *TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($92.99 @ Amazon)
Storage: *TEAMGROUP MP44L 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($105.99 @ Amazon)
Power Supply: *MSI MAG A750BN PCIE5 750 W 80+ Bronze Certified ATX Power Supply  ($69.98 @ Amazon)
Total: $1028.20
Generated by PCPartPicker 2024-08-04 13:04 EDT-0400
what's the use case of your PC?
Also, the part list, doesn't include 4060Ti price, so this is same list, but with random cheapest 4060Ti 16GB GPU.
Video Card: *MSI VENTUS 2X BLACK OC GeForce RTX 4060 Ti 16 GB Video Card  ($429.99 @ MSI)
Total: $1458.19
Generated by PCPartPicker 2024-08-04 13:06 EDT-0400
current PC:
Ryzen 5 5600 |16GB DDR4 3200Mhz | B450 | GTX 1080 ti
PCs I used before:
This one could be better, for clearance reasons, because this one is shorter than Trident.
current PC:
PCs I used before:
U could get mid-high end SSD for same price as that 980 Pro, that 980 Pro is overpriced it's only 1TB
CPU: AMD Ryzen 5 7500F 3.7 GHz 6-Core Processor  ($258.99 @ PC-Canada)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($45.69 @ Amazon Canada)
Motherboard: *ASRock B650 PG LIGHTNING ATX AM5 Motherboard  ($203.04 @ shopRBC)
Memory: *TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($129.97 @ Newegg Canada)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($174.97 @ Amazon Canada)
Video Card: *Gigabyte GAMING OC Radeon RX 7900 GRE 16 GB Video Card  ($734.99 @ Memory Express)
Case: Montech AIR 903 MAX ATX Mid Tower Case  ($109.99 @ Newegg Canada)
Power Supply: Super Flower Leadex III Gold 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($129.99 @ Canada Computers)
Total: $1787.63
Generated by PCPartPicker 2024-08-04 13:15 EDT-0400
current PC:
PCs I used before:
why downgrade?
my i ask why you chose this?
i need the wifi so... no
19 minutes ago, podkall said:
i also get this as recommended memory but i can't find any in my country that CL30 most is CL36 OR CL40 :")
21 minutes ago, podkall said:
too expensive :" 150$/tb in my country, meanwhile silicon us75 is only 100$/tb, is silicion us75 bad or not good? :")
i need rtx for 3d modeling and rendering, rtx way better for my work than gre
the shipping cost is half the price of the case and not available in my country, :"D
The second list was for another thread.
ideally you'd want to get 4070 at least, the problem is how expensive it is...
alternatively used RTX card that's better than 4060ti?
7600x/7600/7500F are all similar in performance
Thermalright is better, if it's dual tower,
but it's whichever's cheaper, the CPU is not a furnace,
the link for Thermalright is same link for previous cooler,
Pro RS is good MB, and since it has wifi version it could be one of the cheapest best,
what other PSUs and other components are available to you?
current PC:
PCs I used before:
 i dont think i can afford more than 4060 ti, its 700$ in my country :" , (pretty much the same pice as rtx 3060 ti 8gb)
theres only used mining rig here, also its very very very not recommended by people of my country to buy used rtx, its 90% scam
i think i will chose 7600x, because the overlooking abilities
some(not all model available) sea sonic, fractal ion, corsair, deepcool, and other brand i never heard and im not sure i can trust them (especially psu part, i dont want it to explode and ruin all component)
is msi mag gl bad? i got some recommendations from pcbuilder on yt
honestly most of my part are from his recommendation, because he explain important stuff about choosing the part and then give recommendations based on tier and price range
7500F can OC, I'm telling you, it's the same CPU
it's good, but I want to see other options in case there's something better
that's good guidance, but is he from your country?
current PC:
PCs I used before:
nope, but my country have zero lastest guide(in fact any proper detail guide for beginner or advance), pc isnt really a thing for most people here (laptop is the standard for most people, but not that many people can afford it) only big business/company have and they usually have already build standard one provided by their company
so better than nothing you know, when i search for part i just check his recommended part and search in my country if it available and at reasonable price, i think i did quite a good job (Maybe :"D?)
also i went from i have no idea what this thing and what it does into i kinda understand what it is and what it does you know
Check out this list, there's an exhausting selection,
see what you find: https://pcpartpicker.com/list/TPHBMV
current PC:
PCs I used before:
in the end i decide with this, bot much change because they are the most fit my budget and available for me (sad asian noises)
PCPartPicker Part List: https://pcpartpicker.com/list/KT8HXk
CPU: AMD Ryzen 5 7600X 4.7 GHz 6-Core Processor  ($198.69 @ Amazon)
CPU Cooler: Thermalright Frost Spirit 140 V3 ARGB 77.8 CFM CPU Cooler
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($104.99 @ Newegg)
Storage: Silicon Power US75 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($115.99 @ Amazon)
im planning to buy them all tomorrow, wish me luck :")
yeah that works, last option would be cheaper decent case, maybe, but I guess that won't save much cash really...
so the 7600X is cheaper than 7600 ir 7500F?
current PC:
PCs I used before:
oh yeah, the seller that sell me that ram said, that ram im about to buy doesnt have amd expo and doesnt fit with the cpu
are they telling the truth or bullshting?
well you don't need EXPO you can just run XMP profile to boost the clocks of RAM, EXPO is just more AMD branded that's it
current PC:
PCs I used before:
7600x and 7600 doesnt have much different in price
7500f is cheaper but, the seller is bit.. sus...
in the online store app im using theres rank in store and the store that selling it doesnt really have good rank, and im not gonna risk anything
okay then, so I guess, if you saved like 10$ there wouldn't be much anything better to swap? then the list is good
current PC:
PCs I used before:
did you check out the other M.2 SSD options or are they all expensive?
current PC:
PCs I used before:
btw you don't have to find all of them, some of those are quite expensive even on US based prices
current PC:
PCs I used before:
sadly yeah, theres some that cheap but its not brand that can be trusted
im still searching tho
theres team group one, and it official from team group them self
but dear god the naming here is confusing af
hit me with some of those names, especially the Teamgroup ones if they are within your budget
current PC:
PCs I used before:
wait i find the Crucial P3 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
2 tb on is strangely expensive (400$) but the 1 tb one are 102$ 😄
they seem to be trusted store too
How much is Silicon Power US75?
current PC:
PCs I used before:
220$ (2tb)
crucial is 240$ (2tb)
the 102$ on is not the plus ver
22 minutes ago, rennatavoid666 said:
220$ (2tb)
yeah you lowkey want plus, though just P3 sounds better than US75,
one idea would be to get a better 1TB drive, and then buy a 2TB NVME for bulk later,
or 1TB drive and whatever TB HDD drive, if they're cheap, because HDDs can be good for bulk storage, if your OS is on NVME all the app cache is on that NVME too by default
current PC:
PCs I used before:
i found Western Digital Black SN770 1tb for 140$
i heard it about on the same lv as samsung 980 pro but hmm...
should i just buy 1tb then later after got more money get 1tb more
