Question about portable power station
Mark65428
5 minutes ago, Mark65428 said:
Can it work like ups ?
just buy a ups
Do I need to change internal battery every period of time ?
well like every battery ever invented it will have to be changed at some point and will not last until the end of the universe
I asked the other question in a wrong way I mean does this station work with removal battery or like phones battery never change ?
After I saw this video I found batteries does not get replaced like UPS
47 minutes ago, emosun said:
just buy a ups
I need to know if it can work like UPS because I am having problems to find good batteries for my UPS in my location
So you want to take the internal battery out and use it? Can you ask the question again?
You generally can't replace batteries in those units, but the lithium cells should last reasonbly long.
What model is it? Normally you can put generic lead acid batteries in those and there fairly cheap.
yes was asking if they are replaceable. how long it last ?
Batteries aren't replacable. I'd guess about 10 years  with some degradation depending on use, temperatures, and more.
But these devices really aren't made to be used as a UPS typically.
According to the page, 1000 charge cycles. How long that takes depends on how you use it. Lithium batteries aren't meant to be plugged in and charging constantly.
