Stereo recording with M-Audio M-Track Duo and Waveform 12
Let's start from the basics.
1) You have both left and right channel coming from the drums to the M-Track? So, you have both inputs in use.
If not, you don't have stereo audio coming from the drums but only mono channel and it's just the M-Tracks/your PCs monitoring that changes the mono to stereo for your enjoyment.
2) You know how to record stereo, so that you have 2 tracks (left and right) and you have set them up correctly so one is from M-Track input 1 and other from input 2 corresponding the e-drums outputs?
If not, you're again only recording one channel and that is in mono and this time there isn't the M-Tracks/your PCs monitoring making it to seem stereo for your enjoyment.
3) Or more kind of 0) Your drums have separated left and right channel outputs?
If not, you're going to need a splitter because the M-Track inputs are mono so they cannot receive stereo signal.
