3 minutes ago, weekdays133 said:
i7 4770k
gtx 980
There's your problem. Not exactly a spring chicken anymore.
AMD R9 9900X | Thermalright FW PRO, 3x TL-H12-X28, 3x TL-P12
Asus Strix X670E-F | 32GB Lexar Ares @ 6400 30-36-36-68 1.55v
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 3x SN770, 6TB
Asus PA602, 2x 200x38, 1x 140x28 | Seasonic Vertex GX-1000
20 minutes ago, weekdays133 said:
my friend while playing fortnite gets between 10 - 60 fps and its not a stable framerate at all, other games like cs2 have no issues, we have tried:
checking temps
different modes (dx11,12,performance)
capping the fps to 60
^ This
Talking performance worse than a handheld like the Steam Deck or ROG Ally with a CPU that old. Some games will be fine, some won't.
I'm assuming you've got everything set to low and on DX11?
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
Just now, Agall said:
^ This
yea
19 minutes ago, weekdays133 said:
yea
Best you can probably do is run the game at a lower resolution, see if that makes it at least playable. 720p if you have to.
The weirdness is that it runs mostly fine still on an i7 3770 with decently stable 60fps+ so it's a bit weird to have it run at 10.
Something's wrong here, this machine should run it way better
