pbo2 tuner is not saving for my 5700x3d. I had dialed everything to -30 and had super great results. Lower heat, Lower power consumption and most importantly, stable FPS in CS2 hehe
but when I restarted the computer, it did not save. How can I solve this?
AMD Ryzen 7 5700X3D | Gigabyte B550M DS3H Rev 1.7 | ADATA XPG Gammix D45 32GB DDR4 (4X8) 3200MHz | Gigabyte RX 7900 GRE GAMING OC 16G |
Thermalright Peerless Assassin 120 SE | 5X Cooler Master Sickle Flow 120mm RGB Fans | Cooler Master TD300 Mesh Case | Gigabyte GP-P650G 650W 80+ GOLD Certified Active PFC  | Lexar NM710 M.2 1TB NVMe SSD Gen 4 | Crucial MX500 500GB 3D NAND SATA | KOORUI 24E3. 24" 1080p Gaming Monitor, 165Hz Refresh Rate, IPS Panel | Razer Blackwidow Chroma V3 Tenkeyless, Razer Deathadder Essential, Razer Blackshark V2 X
https://linustechtips.com/topic/1577300-pbo2-tuner-is-not-saving-for-my-5700x3d/
5700x3D doesn't have PBO2 enabled, so it shouldn't let you. Best you can do is give it a slight manual SoC and Vcore undervolt. PBO2 for 3D v-cache wasn't enabled until 7000x3D.
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
Just use standard PBO in BIOS
The reason for that tool was because there was a time when PBO was not enabled for X3D.  You now have the ability to lower power limits, and use the curve. I would not lower the power limits though.
AMD R9 9900X | Thermalright FW PRO, 3x TL-H12-X28, 3x TL-P12
Asus Strix X670E-F | 32GB Lexar Ares @ 6400 30-36-36-68 1.55v
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 3x SN770, 6TB
Asus PA602, 2x 200x38, 1x 140x28 | Seasonic Vertex GX-1000
Maybe this?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
I cant find any shit on my bios about curve optimizer, my mobo is Gigabyte B550M DS3H Rev 1.7 with a FD Bios
Pic for referencee
