Hi
I got an Mobile Display with an Vesa Mount on the Back and I own nice an sturdy Mini Tripods where I can extend the legs very far so everything stand sturdy.
The major Problem is I could not find (on Aliexpress) some good Tripod to Vesa Adapter who is lightweight for flying to holiday with.
Does anyone know some Magic Key Words to find some Adapter?
Thanks
From AT. :x
https://linustechtips.com/topic/1577029-vesa-to-tripod-mount/
That sounds like something you are going to have to have 3D printed or modify a current vesa mount
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
https://linustechtips.com/topic/1577029-vesa-to-tripod-mount/#findComment-16470050
i think tripods and cameras use a serten thread size so find that then look up x thread size to vasa
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
https://linustechtips.com/topic/1577029-vesa-to-tripod-mount/#findComment-16470076
Your typical consumer tripod thread is also known as 1/4"-20
I think something like this: https://www.camvate.com/products/camvate-vesa-monitor-mounting-plate-with-1-4-20-threads-3291 might get the job done for you. Look through the pics and you'll see how it attaches to a screen.
It looks like the outer holes are unthreaded and meant to connect to different sizes of VESA mounting, while the rest are 1/4-20 threaded to let you screw in your tripod.
https://linustechtips.com/topic/1577029-vesa-to-tripod-mount/#findComment-16470315
