Dram and Cpu light red but pc still boots
Go to solution Solved by Fasauceome,
21 minutes ago, Kevin.Sahlstrom said:
From what I have read people seem to suggest it's normal and just an indicator of the motherboard doing startup checks.
Correct, this is normal and if the system is running fine, you don't have any problems that need fixing. My own PC also does this.
built a computer for a friend and his Dram and Cpu light turns on when he boots. the computer starts fine. I checked the event viewer and there were no errors that would indicate an issue or that were related. I first suspected it could be his old monitor because it's a Dell monitor from 2013 that connects with a VGA to HDMI and the VGA light did start the first 2 boots but hasn't turned on since. the monitor also takes forever to start on boot and we are still unsure if that is just the monitor or the PC booting slowly. From what I have read people seem to suggest it's normal and just an indicator of the motherboard doing startup checks. but it's not something I've seen on other computers before, at least not something I've seen where it doesn't cause any issues whatsoever.
feels kinda od for the Dram and CPU lights to turn red on boot without causing issues. any suggestions?
His specs are-
4070 Super Eagle oc triple
msi mag b650 tomahawk wifi
ryzen 9 7900x
32gb 2x16 6000mtz corsair vengeance
C drive: 1tb gammix s70 blade
https://linustechtips.com/topic/1576831-dram-and-cpu-light-red-but-pc-still-boots/
diagnostic lights on a mb have nothing to do with monitors.
check for a bios update but other than that if the machine is working fine then it's fine.
Primary PC:
Alright, Iv'e attached a video. But I belive people on this forum so seems to be safe enough to assume he is gonna be fine
I also have an orange light when my PC's gone through boot and everything's good.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec 1000W 80+ Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64- Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
