how to plug ARGB fans
i recently bought a new pc it was a custom build but best buy where i got it from built it for me it has gigabyte a620m gaming x ax mother board . when i open the GCC(GIGABYTE CONTROL CENTER) and open rgb fusion there is two pin on the bottom of the motherboard which i can control and the case that i m using is called redragon paktis 3 wich have 3 prebuilt argb fan (said on the website).so my question is  i have right now all the  3 front  fans are connected to the reset button when i press it it toggle between mods so can plug the cable insted of the restart button to the d led pin in my mother board
Find the fan's ARGB connector, take a pic, and post the pic here.
Find the two headers on the motherboard, take a pic, and also post the pic here
Refresh before you reply
Huh?
Typically these case fans are connected to the fan hub that comes with the case, and often the fan hub is connected to the reset button, pressing the reset button toggles the modes of the fan hub which changes fan colors.
Again, typically these fan hubs have xx modes plus one "off" mode, which isn't actually off...
If you connect the fan hub to the argb or rgb fan header then that "off" mode will follow whatever the mobo is telling it to be.
EDIT: Found a pic of the fan hub which came with an older Redragon case (Grimlock GC-602)
NOTE that RGB header pins were missing on that one!
I soldered those 3 on, and used some dupont wires to to connect it to the RGB header on the mobo.
And I suspect yours is similar... hopefully Redragon improved over the years and yours doesn't need soldering 😄
VGhlIHF1aWV0ZXIgeW91IGJlY29tZSwgdGhlIG1vcmUgeW91IGFyZSBhYmxlIHRvIGhlYXIu
^ not a crypto wallet
Sorry I didnt see the replies but here are the pictures you asked for (sorry for the dirt i live in kind of stormy town full of dirt)
here are the pics
30 minutes ago, NotJellyPig said:
here are the pics
I'm guessing you meant this :
If so, there's no way you will be able to connect those connectors to your motherboard without some sort of adapter.
Also, I'm not sure, but there is a chance that those fans lighting are "static", meaning can't be controlled through motherboard / software.
