4050 mobile vs 3050 mobile for productivity
Go to solution Solved by YoungBlade,
3 hours ago, VL_Hermes said:
Any idea how much of an upgrade 4050 mobile is to 3050 mobile for productivity tasks? mainly programming and related task honestly
For programming, unless you're coding up games or doing ML work that uses a graphics card - or you're gaming on the side, a laptop dGPU is a complete waste of money.
You need to put your money into a good CPU and plenty of RAM - that's what you need for programming. You can just use the integrated graphics on the CPU, and you'll be more than fine.
Again, unless you're coding up something like a video game or using CUDA. In that case, a GPU is important, but unfortunately, both of those options are likely insufficient - unless the work is really basic.
What sort of programming? Most of my programming workload can be done off a 2018 i3 iGPU, only rendering and gaming did I require a GPU and for the task the AMD VEGA APU was good enough.
Even a 3050 will be overkill for 90% out there.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec 1000W 80+ Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64- Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
What kind of "productivity"?
If you're editing video, the newer generation NVENC in the 4050 might help.
If you're word processing and doing spreadsheets, it won't make a difference either way.
On 6/25/2024 at 11:17 PM, 12345678 said:
use online benchmarks. or state apps
programming means nothing
that said either 4/6gb vram are bad for most gpu intesinve applications
and mind that gaming laptops suck. they're not really laptops
they are heavy, loud, battery sucks, and performances suck too unless you're plugged in the outlet
I learnt it in the hard way
No need for this comment the OP didn't ask for your opinion on gaming laptops.
What do you mean programming? , it's such a generalized term and could mean you need a raspberry PI or a 4090.... more details please OP.
CPU : Ryzen 7 7800X3D @ -30mv All core
CPU Cooler : Thermalright Frozen Prism 240mm AIO
Mobo : Asrock B650m Pro RS Wifi
Ram : 32GB (2X16GB) Lexar Ares 6000MHZ CL 28-36-36-68
GPU : MSI Gaming X Slim 4070Ti Super 16GB ( 308W PL +140 Core +1000 Memory )
Storage : 2TB Verbatim Vi5000 Gen 4 NVME
PSU : Thermalright TG-750w 80+ Gold ATX 3.0 PCIE 5.0
Case : Fractal Design Pop Mini MATX
Case Fans : 3 X Thermalright TL-C12C-S RGB
Monitor :27" Samsung Odyssey G5 2560 x 1440 180 HZ IPS
Keyboard : HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
