Phanteks enthoo pro tempered glass
cubabori
I dont remember how to put together the glass panel door or what screws go in the hinge that hold it. Help would be appreciated.
Looks like the hinges should be permanently attached, you just line up the holes on the hinge pieces the panel has and drop it down onto the case's hinge pegs. Then the two short, fat thumb screws go on the other end of the panel to hold it closed.
Main PC
CPU: i3 12100F
Cooler: Noctua NH-L12S
Motherboard: ASRock Z690 ITX/ax
RAM: 2x16GB 3600Mhz Team Group T-CREATE DDR4
GPU: Intel ARC A770 16GB LE
Storage: 1TB MP34 + 2x 1TB MX500
PSU: EVGA 850W GM
Case & Fans: Fractal Design Node 304 - 2x Noctua NF-A9 + Noctua NF-A15
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 15" M3 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
Yeah, tho I meant like I took the entire thing off to build in the chassis and now im pretty lost on how it goes back on hinge wise. Checked the case manual and afaik I see no specification on what screws are used to keep the panel on the hinge like a door.
I think i figured it out, but may have to order the screws that hold it as I misplaced half of them.
Looked in the hardware box and found screws good enough as a replacement and figured out how it went back on. Thanks for reading.
