Dell UltraSharp 24 USB-C Hub Monitor - U2421E - MST Questions
Aphos
Go to solution Solved by AbydosOne,
1 hour ago, Aphos said:
I've picked up a Dell U2421E to use in place of my docking station as sometimes it's not the most reliable thing. The current monitors that I have don't support MST so I'm looking to pick up another 1 or 2 to daisy chain. When I asked Dell for their MST supported monitors they only gave me 1 suggestion of a $500 monitor that is also a hub. Should I just return the U2421E and get a newer one as it looks like it is discontinued. If not are there any MST monitors that you can point me to that I can use?
MST is a subset of DisplayPort. Any monitor with a DP input is "supported" as a secondary monitor.
(or, if you're sneaky, you can use an active DP->HDMI adapter and use pretty much any monitor.)
Main System (Byarlant): Ryzen 7 5800X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 16GB G.Skill DDR4 3200MT/s CAS-14 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 960 PRO 512GB / 4× Crucial MX500 2TB (RAID-0) | Corsair RM750X | a 10G NIC (pending) | Inateck USB 3.0 Card | Hyte Y60 Case | Dell U3415W Monitor | Keychron K4 Brown (white backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi (all-around awesome machine)
Proxmox Server (Veda): Ryzen 7 3800XT | AsRock Rack X470D4U | Corsair H80i v2 | 64GB Micron DDR4 ECC 3200MT/s | 4× WD 10TB / 4× Seagate 14TB Exos / 8× WD 12TB (custom external SAS enclosure) / 2× Samsung PM963a 960GB SSD | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-16i HBA | Fractal Design Node 804 Case (side panels swapped to show off drives) | VMs: TrueNAS Scale; Ubuntu Server (PiHole/PiVPN/NGINX?); Windows 10 Pro; Ubuntu Server (Apache/MySQL)
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s CAS-22 | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | Mellanox ConnectX-2 10G NIC | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Camera: Sony ɑ7II w/ Meike Grip | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance 512GB SDXC card
Network:
                           ┌─────────────── Office/Rack ─────────────────────────────────────────────────────────────────────┐
Google Fiber Webpass ────── UniFi Security Gateway ─── UniFi Switch 8-60W ─┬─ UniFi Flex XG ═╦═ Veda (X550->Proxmox)
(500Mbps↑/500Mbps↓)                             UniFi CloudKey Gen2 (PoE) ─┴─ Veda (IPMI)    ╠═ Veda-NAS (X550->PM->TrueNAS)
╔════════════════════════════════════════════════════════════════════════════════════════════╩═ Narrative (Asus USB 2½G NIC)
║ ┌── Closet ───┐    ┌─────────────── Bedroom ───────────────────────────────────────────────┐
╚═ UniFi Flex XG ═╦╤═ UniFi Flex XG ═╦═ Byarlant
   (PoE)          ║│                 ╠═ Narrative (Cable Matters USB-PD 2½G Ethernet Dongle)
    Kitchen Jack ═╝│                 ╚═ Jesta Cannon*
    (testing)      │        ┌──────── Media Center ──────────────────────────────────────────┐
                   └──────── UniFi Switch 8 ─────────┬─ UniFi Access Point nanoHD (PoE)
Notes:                                               ├─ Sony Playstation 4
─── is Gigabit / ═══ is Multi-Gigabit                ├─ Pioneer VSX-S520
* = cable passed to Bedroom from Media Center        ├─ Sony XR65A80K (Google TV)
** = cable passed from Media Center to Bedroom       └─ Work Laptop** (Startech USB-PD Dock)
Retired/Other:
Laptop (Rozen-Zulu): Sony VAIO VPCF13WFX | Core i7-740QM | 8GB Patriot DDR3 | GT 425M | Samsung 850EVO 250GB SSD | Blu-ray Drive | Intel 7260 Wifi (lived a good life, retired with honor)
Testbed/Old Desktop (Kshatriya): Xeon X5470 @ 4.0GHz | ZALMAN CNPS9500 | Gigabyte EP45-UD3L | 8GB Nanya DDR2 400MHz | XFX HD6870 DD | OCZ Vertex 3 Max-IOPS 120GB | Corsair CX430M | HooToo USB 3.0 PCIe Card | Osprey 230 Video Capture | NZXT H230 Case
TrueNAS Server (La Vie en Rose): Xeon E3-1241v3 | Supermicro X10SLL-F | Corsair H60 | 32GB Micron DDR3L ECC 1600MHz | 1x Kingston 16GB SSD / Crucial MX500 500GB
