Budget (including currency): $2000 CAD(including taxes and a monitor)
Country: Canada
Here is my build: https://ca.pcpartpicker.com/list/XdwP4M, is there anything that i should change? I'll be using this pc for some gaming, some programming and just casual usage, i might also do some blender.
https://linustechtips.com/topic/1574559-new-to-pc-building-need-advice/
That dual tower cpu cooler won't clear that RGB RAM due to the tall heatsinks on said RAM. Also I would consider 1080P.
https://www.msi.com/Motherboard/B760-GAMING-PLUS-WIFI
https://www.bequiet.com/en/powersupply/4073
PCPartPicker Part List
CPU: Intel Core i5-13600KF 3.5 GHz 14-Core Processor  ($319.00 @ Amazon Canada)
CPU Cooler: Thermalright Peerless Assassin 120 SE ARGB 66.17 CFM CPU Cooler  ($46.90 @ Amazon Canada)
Motherboard: *MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard  ($219.99 @ Amazon Canada)
Memory: *G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($144.97 @ Newegg Canada)
Storage: TEAMGROUP MP44L 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($154.97 @ Newegg Canada)
Video Card: Gigabyte WINDFORCE OC GeForce RTX 4060 8 GB Video Card  ($389.99 @ Canada Computers)
Case: Phanteks XT PRO ULTRA ATX Mid Tower Case  ($109.98 @ Newegg Canada)
Power Supply: *be quiet! Pure Power 12 M 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($114.99 @ Canada Computers)
Monitor: Asus TUF Gaming VG27AQ1A 27.0" 2560 x 1440 170 Hz Monitor  ($249.99 @ Canada Computers)
Total: $1750.78
Generated by PCPartPicker 2024-06-23 11:16 EDT-0400
Country: Canada
4060 is baaaaad, in gaming at 1440P you need a better 4070
To stay on budget I've downgraded the CPU to a 12600K, 15% slower in games at 1080p (less at 1440P if you're GPU limited) and 4 less ecores but 30% cheaper
Also swapped the RAM for lower profile kit to have clearance for the cooler
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor  ($209.00 @ Canada Computers)
Motherboard: MSI PRO B760M-A WIFI Micro ATX LGA1700 Motherboard  ($234.73 @ Amazon Canada)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($144.97 @ Newegg Canada)
Video Card: Zotac GAMING Twin Edge OC GeForce RTX 4070 SUPER 12 GB Video Card  ($714.99 @ PC-Canada)
Case: Phanteks XT PRO ULTRA ATX Mid Tower Case  ($119.98 @ Newegg Canada)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($131.50 @ Vuugo)
Total: $2007.03
Generated by PCPartPicker 2024-06-23 13:22 EDT-0400
Total: $2007.03
Save on the board and psu.
Total: $1965.78
Generated by PCPartPicker 2024-06-23 13:34 EDT-0400
Total: $1750.78
What other cooler do you recommend?
Total: $2007.03
That's still way over my budget, idk why but pcpartpicker isn't including sales tax for some reason, for me its 13%, maximum budget before tax is aorund $1750
