Testing lian li argb cables 28pin and 3x8pin
frozensun
Go to solution Solved by tkitch,
8 minutes ago, frozensun said:
I just want to test/try them out without connecting to MoBo.Can I do that?
what part of "no" is escaping you?
The RGB will not turn on without a motherboard.
Hi guys.
I have some Lian Li argb/rgb cables 28 pin and 3x8 pin set.
May I try the rgb lighting connecting them with PSU, without plugging them to motherboard?
Please do not take offence for my apparent confusion or rudeness,it's not intent me to be like that,it's just my BPD,be nice to me,and I'll return twice better,be rude and usually I get easly pissed of...I'll try to help anyone here,as long as it's something I dealt with,and even if you think I'm rude or not polite,forgive me,  it's not me it's my BPD.
Thanks for understanding.
no, the motherboard controls the RGB
Not rfb control, power supply?
If i connect the cables to external power supply will they shine?
no, the motherboard controls the RGB, not the power supply.
Aha okay.
