This is the current specs that I am running:
CPU: Ryzen 5 5600x
CPU Cooler: Cooler Master Hyper 212 LED Turbo ARGB
GPU: Colorful GTX 1050ti Tomahawk V2 4gb
Motherboard: Gigabyte B550M Aorus Pro
RAM: Gigabyte Aorus 2x8gb 3200mHz
Storage:
  • 1TB Western Digital HDD
  • 240gb m.2 SATA from WD Green
PSU: Thermaltake TR2 S 700w
Case: Rakk Haliya mATX
Monitors:
  • Gigabyte G24F 1920x1080 165Hz
  • HP 24F 1920x1080 75Hz
I want to upgrade my GPU and my storage so that it'll be significantly larger and faster. Should I upgrade my GPU now? If so, which GPU matches my system best at the given budget? I just want to be able to play Warzone, RDR2, and other GPU-intensive games at high settings. Thank you!
Budget (including currency): around $150-$350 (Php 8,000-Php 20,000)
Country: Philippines
Games, programs or workloads that it will be used for: Valorant, Warzone, MW2 & MW3, GTA, RDR2, Ghost of Tsushima, 2K, and Madden.
https://linustechtips.com/topic/1574547-advice-on-whether-or-not-to-upgrade/
CPU: Ryzen 5 5600x
Storage:
Monitors:
Get rtx gpu
Amd Ryzen 5 5600 Zen 3 OC 4.6Ghz
RTX 3070 gaming gigabyte
32GB patriot 3600 MHz
Casual gamer since dune 2 and wolf 3d and dukem nukem 3d
https://pcpartpicker.com/user/apokhallipsa/saved/j4rn23
CPU: Ryzen 5 5600x
A Radeon RX 6600XT, 6650XT, 6700 (non-XT), or 7600 would be the best option. Eventually an RTX 3060Ti or 4060.
Also, you need more SSD storage. I would recommend a 1TB NVME m.2 for the OS, games, etc.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
