Is it worth the decrease in hz for a 1440p monitor compared to a 1080p monitor?
bacone
Compared to a 240hz 1080p monitor, would a 1440p 165hz monitor be worse?  I don't know if this is important or not but, my laptop specs are AMD Ryzen 9 5900 and RTX 3050.
You have a stronger cpu than gpu so 1080p 240 may work better. But they are both good options depending on what you play and what type of experience you want.
PC Specifications: Intel i9-14900KF, 5.7GHz all core locked, 5GHz ring, 1.35v Medium LLC, E-cores and HT disabled | MSI RTX 4090 Gaming X Trio | Arctic Liquid Freezer II 360 + Thermal Grizzly contact frame | 2x16 G.Skill Trident Z5 7400MHz 34-44-44-34 1T 1.45v (Maxed Subtimings, 52ns latency) | Gigabyte Z790 AORUS Elite AX | Windows 10/11 EVGA SuperNOVA 1000 T2 Phanteks P400A (Black non-rgb version, Phanteks T30 fans 3 intake (On AIO), 1 exhaust) | SK Hynix Platinum P41 2TB PCIe 4 SSD
Displays: MSI MAG 271QPX 1440p 360Hz 27" QD-OLED
Desktop Audio: STAX SR-007 MK2 Electrostatic Headphones (Current revision) | STAX SRM-400S Amp | Schiit Bifrost 2/64 (NOS mode, USB in, XLR out)
Mobile Audio: Sennheiser IE 900 IEMs w/ 4.4mm cable | FiiO KA13
Peripherals: Razer Huntsman V2 Full size wired with linear optical switch | Logitech G502 Hero
I plan on playing Valorant/FPS games, I’m going for preformance + good visual. Idk if this is relevant but I’m trying to up the saturation
I would not go to 1440p with a 3050 mobile.
Please use the mark as solution feature if your query was resolved.
If multiple people people contributed to a solution, pick the most helpful contribution.
https://pcpartpicker.com/list/TM4Hyg
Okay, thank you!
For games like that 240hz will be way more beneficial. A 3050 mobile will probably struggle with higher than 1080p anyway in anything super heavy.
As long as you stay in a higher refresh rate, and not have to drop to 60Hz, then I'd say 1440p lower refresh is better.
With your particular example of 1080p 240Hz vs. 1440p 165Hz, I'd recommend the 1440p variant to 90% of people.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
