Looking for theoretical advice on building a new system.
Hello everyone,
I am looking for some advice or suggestion on building a new system.
The specs I am looking for creating a new system are the following:
AMD Ryzen 7 7800X3D
Gigabye GeForce RTX 4070 Super (Windforce OC 12GB DLSS3)
ASUS TUF Gaming B650-Plus
Kingston Fury Beast Black 32GB (2x16GB 5200MHz DDR5 CL40 DIMM)
Kingston KC3000 M.2 Pcie 4.0 NVMe 2TB
Cooler Master MWE 750W V2 80+ Gold
Corsair 3000D RGB Tempered Glass Black CC-9011255-WW
Corsair H150 RGB 360mm CW-9060054-WW
I am not incredibly tech savvy, and haven't really build a complete system from the ground up before so I mixed and matched components within budget. And now I wonder on it's complete compatibility and expected performance.
My aim for this system is to use it for my analytical work and play games on off time.
I would appreciate any advice or suggestion on either expected performance or possible adjustments on the specs.
Many thanks in advance!
9 minutes ago, Maekoz said:
Hello everyone,
AMD Ryzen 7 7800X3D
It's ok but if you're doing more "analytic" stuff than gaming a 14600K may perform better (with a Z790 board)
But with the 7800X3D you don't need an expensive AIO, any sub $40 aircooler is good and save money
RAM is slow at 5200CL40, try to get 6000CL30
System : AMD R9  7950X3D CPU/ Asus ROG STRIX X670E-E board/ 2x32GB G-Skill Trident Z Neo 6000CL30 RAM ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Thermalright Peerless Assassin 120 cooler (with 2xArctic P12 Max fans) /  2TB WD SN850 NVme + 2TB Crucial T500  NVme  + 4TB Toshiba X300 HDD / Corsair RM850x PSU
Alienware AW3420DW 34" 120Hz 3440x1440p monitor / ASUS ROG AZOTH keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
Thanks for the feedback,
I think the ratio would be roughly 70/30 work/personal, is the general performance between 7800X3D and 14600K that much better with bulky data?
Just to be sure, with 14600K you are talking about the i5 correct? For example Intel Core i5-14600KF.
For cooling I would like a suggestion then strong enough and compatible with 7800X3D and sadly 6000CL30 is unavailable at the place where I intend to place my order for parts.
In gaming the 7800X3D is faster by maybe 10% tops at 1080p, but the 14600K/KF is 30% faster in total horsepower due to its ecores
But Intel likes fast RAM and 7800X3D don't care that much about it so maybe stick to it if you can't get >6000MHz RAM
As for cooler look at Thermalright dual tower coolers Peerless Assassin or Phantom Spirit, they're good, I run my 7950X3D with a PA no problem ! 🙂
PCPartPicker Part List
CPU: *AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($339.99 @ B&H)
CPU Cooler: *Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  ($35.90 @ Amazon)
Motherboard: *Asus TUF GAMING B650-E WIFI ATX AM5 Motherboard  ($159.99 @ Newegg)
Memory: *Silicon Power Value Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($94.97 @ Amazon)
Storage: *Acer Predator GM7000 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($139.99 @ Amazon)
Video Card: *Gigabyte WINDFORCE OC GeForce RTX 4070 SUPER 12 GB Video Card  ($599.99 @ B&H)
Case: *Phanteks XT PRO ULTRA ATX Mid Tower Case  ($71.98 @ Newegg)
Power Supply: *SeaSonic FOCUS GX-750 ATX 3.0 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ B&H)
Total: $1532.80
Generated by PCPartPicker 2024-06-22 21:15 EDT-0400
CPU: *Intel Core i7-13700KF 3.4 GHz 16-Core Processor  ($291.56 @ Amazon)
Motherboard: *MSI PRO Z790-P WIFI ATX LGA1700 Motherboard  ($190.00 @ MSI)
Total: $1514.38
Generated by PCPartPicker 2024-06-22 21:17 EDT-0400
Total: $1532.80
Total: $1514.38
Thank you for the suggestions I will do my research on your listed specs!
Thank you for the insight, I will check with my provider if there is a possibility to get 6000Mhz CL30 RAM which now is listed as incompatible with any Motherboard selections, for combining the parts as 30% raw horsepower does sound promising over 10% gaming performance so the i7 14600KF would hold my preference.
The listed coolers are sadly unavailable in my provider, but I've found something I believe is quite similar in the ENDORFY Fera 5 Dual Fan, if this is not comparable let me know.
Thanks again!
Thanks again!
The ENDORFY Fera 5 is single tower only, may be okayish with a 14600K but not sure it's enough if you push it to 180W
So then for example a be quiet! - The Dark Rock PRO 5 would be what's a dual tower yes?
Indeed 🙂
Dual towers have much more metal surface to dissipate heat, so are recommended above around 125W TDP
