Aluminum Mini ITX Case with PCIe Riser, JOYJOM Mini PC Case, SFF Small Form Factor PC Case, TX Computer Gaming Case supports GPU Graphics Card (Black)
This is a small sandwich case, could I take the tray iut & fit it in the Original Xbox, I would link it, but it is on amazon & would be advertissing. Angainst the rules, so.
GIGABYTE B550I AORUS PRO AX (AM4 AMD/B550/Mini-Itx/Dual M.2/SATA 6Gb/s/USB 3.2 Gen 1/WiFi 6/2.5 GbE LAN/PCIe4.0/Realtek ALC1220-Vb/DisplayPort 1.4/2xHDMI 2.0B/RGB Fusion 2.0/DDR4/Gaming Motherboard) ,AMD Ryzen 7 5800X 8-core, 16-Thread Unlocked 4.7 GHz, TEAMGROUP T-Force Vulcan Z DDR4 32GB (2 x 16GB) 3200MHz (PC4 25600) Ram, EVGA GeForce RTX 3060 Ti XC Gaming, 08G-P5-3663-KL, 8GB GDDR6, Metal Backplate, LHR
If
  • original Xbox uses ITX mounting holes,
  • dimensions of the motherboard fit,
  • you figured out the power supply dilemma,
  • you figured out the power button situation,
  • made sure you are good in all other aspects
If you have made your research, yeah, walk in the park.
The MB & GPU can go on one side, a SFX can sit flat on the other. It sucks the front USB needs an adaptor, but the power is normal voltage right? It would be awesome to have a case build for not that much, but it is $$$$.
You are in over your head with this project, I would recommend not bothering.
Linking to products is fine, it's only advertising if you're affiliated with it. Even if it was, giving everything needed to find it but not the link would still violate it.
This thread makes no sense without a reference.
F@H
GPD Win 2
Ya, thought so to.  Looks like it would make a nice little SteamMachine though.
Quote
https://www.amazon.com/gp/product/B0BLXY7S4Y/ref=ox_sc_saved_image_6?smid=A26YYQ0U8ZSIL1&th=1
