Timing for 3600mhz to 2667mhz
Go to solution Solved by Levent,
Just now, BejoBarokah said:
I see, do you have any recommendation configuration for the RAM? Or maybe some resources so i can set it myself? Thank you
Easiest way to get started is by using Ryzen dram calculator way. It is not great by any means but it gets you going in terms of timings and median frequencies.
Hi, so i just added my RAM. Before, it was Corsair Vengeance 2x16GB 3600mhz with 18-22-22-42 timing. Now i added 2 more identical RAM, so it is 4x16GB 3600mhz. The motherboard is Asrock B550M Pro4.
Anyway, turns out my PC can't handle running the 4 RAM stick at 3600mhz. So now i'm forced to use 2667mhz, per motherboard manual. I heard if you reduce the RAM speed, you can reduce the RAM timing. Since there are no profile for the speed, i need to configure it manually. But i dont know what should my RAM timing is if i reduce the speed from 3600mhz to 2667mhz. So can somebody told me what timing i should use? Or maybe some resources so i can pick the right timing.
Thanks
No you are not. None of my motherboards claim they support 4 dimms at 3600mts. All of them run at 3800mts.
Ah sry, for i dont have much knowledge about this. What i refer to is this image
From my memory, it is in the user manual. But maybe i'm wrong, forget, or misinterpreted.
That is what they tested at. I have two Asrock B550 boards and two GB B450 boards that both dont support 3800mts yet all of which run at those said frequencies. I dont use XMP. Heck my B550 PG Riptide runs 128Gs of rams at 3800mts. Rams are not even on the QVL either.
Ah ok, thank you. I think ill try it
1 hour ago, BejoBarokah said:
So can somebody told me what timing i should use? Or maybe some so i can pick the right timing.
I'd just choose a low latency 2666 kit as the basis, there were quite a few around because 2666 was the top stock speed for some time.
Anyway, turns out my PC can't handle the 4 RAM stick at 3600mhz. So now i'm forced to use 2667mhz, per motherboard manual.
What is your CPU? It likely has more influence than the motherboard here. You may also find that a small bump to the voltage your sticks are supposed to use helps.
Ah sry, for i dont have much about this. What i refer to is this image
From my , it is in the user manual. But maybe i'm wrong, forget, or misinterpreted.
This table is copied from AMD's memory specification for Ryzen 5000, but pretty much every CPU can exceed these minimum specs. By how much on average? I don't know.
It's Ryzen 5 3600
