Corsair LL120 RGB not working with 6 fans
Solved by knight_40k,
UPDATE: **[SOLVED]**
I found the problem.
Within the iCUE software, I had to change the lighting channel to tell it there was no device connected, ie: remove the previous device of "LL RGB Series Fans". Then I re-added the device and was able to remove the second hub, plug all fans to a single hub, and now it works like it should!
Stupid software design that the fans are not plug and play, making it look like a hardware problem. I hope this helps someone else with the same fans having the same or similar issue.
