Can motherboard coil whine infect others components?
8 minutes ago, kzoxi said:Well At first I suspected the PSU it was making some weird spinning noises from time to time (unsure about if it comes from there actually )then the coil whine started after about a month at first I suspected the GPU. But today I decided to inspect the noice further opened the back side of PC case and the sound is the loudest around the CPU area. I can technically return the PSU and the Motherboard but they have a weird policy of inspecting their things and they do take a long time actually checking them and giving a refund. Soo I was thinking to sit this through for when warranty is coming to its end. And change these parts. As long as the coil whine won't spread to my GPU or harm my GPU in any way shape or form my plan should be fine can't return it :(.
I have seen some cases similar to what you describe.
The coilwhine won't spread to your GPU and coilwhine in itself is completely harmless! Its annoying but its not dangerous in any way
