Best White Speakers for below 75$?
Here's all the details that I want for some affordable speakers:
Speakers need to be white, 2.0 Audio Channel & have 3.5mm connection. I will put them on separate wall shelves, one left and one right above my monitor. Speakers should have as good of a bass as possible at that price point and these criteria.
What I'll be doing: Listening to music, making music myself (not professional, just fun/amateur), story games (no comp/audio intensive "left/right determinable" kind of games).
What is my best purchase here for under 75$?
https://linustechtips.com/topic/1573808-best-white-speakers-for-below-75/
9 minutes ago, Fluuwu said:
I'm looking for PC Speakers for under 100$. What I'll be using them for is listening to music, sometimes also making music myself (not professional, just fun), occasional gaming (story games).
I want to have clear sound, good highs & lows and good bass.
I feel like I'm delulu here, since it doesn't seem realistic xD
For that price, the Klipsch promedia 2.1 is your best option.
The recommended studio monitors don't come large enough at that price point for good bass, as they're 3" usually.
The 5" ones for around $200 though are very good and what I would recommend if you have space and funds.
Any from Mackie, presonus, edifier, etc.
Onyx: AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 1000 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
OnePlus Ecosystem:
Other Tech:
The Klipsch promedia 2.1 aren't available here in Switzerland 😕
Maybe then a Logitech setup, but I shy away from them these days.
Look at studio monitors under your budget then.
OnePlus Ecosystem:
Other Tech:
11 minutes ago, Fluuwu said:
The Edifiers are not under 100$ sadly 😕
Maybe these then: https://www.digitec.ch/en/s1/product/edifier-r1280t-1-pair-42-w-hi-fi-home-cinema-speakers-10410075
Had those at one point, sounded good.
What's this useful for?
46 minutes ago, Tan3l6 said:
That's a great find.
OnePlus Ecosystem:
Other Tech:
(preferable if there's a white option available)
I have the creative pebble plus - sounds great, 2.1 config with 2 speakers and a subwoofer, and about $40. You could probably get better speakers for a $100 budget but I think these sound incredible.
They also look cool.
https://www.amazon.com/Creative-USB-Powered-Down-Firing-Subwoofer-Far-Field/dp/B07NWLWM9B/ref=sr_1_1
hi
These are not white tho... 😞
So my last post about this wasn't detailed enough, so here's all the details that I want.
Speakers need to be white, 2.0 Audio Channel & have 3.5mm + Bluetooth connection. I will mount them on separate wall mounts, one left and one right. Speakers should have as good of a bass as possible at that price point and these criteria.
What I'll be doing: Listening to music, making music myself (not professional, just fun/amateur), story games (no comp/audiophile games).
What is my best purchase here for under 100$?
Sorry, didn’t realize they had to be white… I know they make a white version, but that might be the one without a subwoofer
Edit: they do make a white one, but it’s the cheap one without the subwoofer.
https://www.amazon.com/Creative-USB-Powered-Speakers-Far-Field-Radiators/dp/B0791J2658/ref=mp_s_a_1_1
hi
check my new post, i fumbled a bit on this one with the criteria for the speakers xD
With all this extra criteria, I’m stumped lol
hi
Doesn’t meet your budget, but I loved the Swan M10 in my college days. White and 2.1
nowadays they’re called Swan M10 Plus
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
Speakers need to be white, 2.0 Audio Channel & have 3.5mm + Bluetooth connection. I will put them on separate wall shelves, one left and one right above my monitor. Speakers should have as good of a bass as possible at that price point and these criteria.
