Looking for a better wireless router, something with good wireless capabilities, 2.5G WAN, and at least one 2.5G LAN port
atxcyclist
I have a cheap "gigabit" router that may have gigabit WAN and LAN, but it cannot hang with routing that level of traffic and frequently lags with multiple people using it (maybe even overheats?). I tried building an opnsense machine but the configuration is just beyond my level of knowledge, and the household internet cannot be down for hours while I figure it out. I have a few that I will link that seem to meet these criteria but I clearly don't know much about the hardware. I currently have gigabit service but could move to something faster in the future, so if I'm going to spend some money I might as well get something with native 2.5G support.
https://www.amazon.com/GL-iNet-GL-MT6000-Multi-Gig-Connectivity-WireGuard/dp/B0CP7S3117/ref=sr_1_2_sspa?crid=1K34T7OYXFWKZ&dib=eyJ2IjoiMSJ9.kUQ12g6zevg5aXkkpWUACpQw0yU5zZgMNoOGVmblCbDhkeeSdYdcNWLW8PFntdwFgLJy1C2tf1Noh5-BE9V53H3eb1yYNd_f_ZnIiPtseAE2E0q97MfwKPencXarZiJ8mKkF4lxRi2kvqS-M28AKmTDKmGsGsh8qQVv3O2uJSSDOLj8rVs2dgF7riZSg31cDelqdG7ho1akO7uK5nh3KzoQCLW2vmREa96f43JU2blw.895e3scgO7hhsfyHb8McVXCKiR0dNxsaphA0UVl9E3I&dib_tag=se&keywords=2.5g+router&qid=1718236806&sprefix=2.5g+router%2Caps%2C92&sr=8-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
https://www.amazon.com/TP-Link-Tri-Band-Archer-BE550-HomeShield/dp/B0CJSNSVMR/ref=sr_1_3?crid=1K34T7OYXFWKZ&dib=eyJ2IjoiMSJ9.kUQ12g6zevg5aXkkpWUACpQw0yU5zZgMNoOGVmblCbDhkeeSdYdcNWLW8PFntdwFgLJy1C2tf1Noh5-BE9V53H3eb1yYNd_f_ZnIiPtseAE2E0q97MfwKPencXarZiJ8mKkF4lxRi2kvqS-M28AKmTDKmGsGsh8qQVv3O2uJSSDOLj8rVs2dgF7riZSg31cDelqdG7ho1akO7uK5nh3KzoQCLW2vmREa96f43JU2blw.895e3scgO7hhsfyHb8McVXCKiR0dNxsaphA0UVl9E3I&dib_tag=se&keywords=2.5g%2Brouter&qid=1718236806&sprefix=2.5g%2Brouter%2Caps%2C92&sr=8-3&th=1
Edit: Ended up going with the GL-iNet, saw there was a recent Short Circuit episode on it and there was an excellent promotional discount even through Amazon. In the time since I posted this thread my current router dropped connection several times when a few people were on the internet, so no time better than the present.
My Current Setup:
AMD Ryzen 5900X
Kingston HyperX Fury 3200mhz 2x16GB
MSI B450 Gaming Plus
Cooler Master Hyper 212 Evo
EVGA RTX 3060 Ti XC
Samsung 970 EVO Plus 2TB
WD 5400RPM 2TB
EVGA G3 750W
Corsair Carbide 300R
Arctic Fans 140mm x4 120mm x 1
I was going to suggest you watch the video, too.
These GL.iNet routers are based on a modified version of OpenWRT, which is a very good Linux-based router OS. So I expect that it should work well for your needs.
It was extremely easy to get set-up, and I get very good throughput on wireless. Even my older devices using 2.4ghz look like they have better connections.
My Current Setup:
AMD Ryzen 5900X
EVGA RTX 3060 Ti XC
WD 5400RPM 2TB
EVGA G3 750W
Plus even if GL.iNet drop support, you still have mainline OpenWRT you can fall back on for future firmware updates.
I was really surprised when I myself got the GL.iNet GL-X3000/ Spitz AX and found they leave the full OpenWRT functionality in the Advanced section.  This is how all OpenWRT based routers should work!
