Would this be compatible, and do i also need more fans? If yes which should i get and should i get a hub? (more of a black build)
Budget (including currency): Around 2600 Canadian (also included tax, for me its 15%)
Country: Canada
Games, programs or workloads that it will be used for:  Mainly high quality, heavier games, or even just some smaller things (mainly trying for quality)
Case: Corsair 4000D Airflow 4000D Black Steel / Plastic / Tempered Glass ATX Mid Tower Computer Case
Motherboard: MSI PRO B650M-P AM5 Ryzen 7000 DDR5 SATA 6G 2x M.2 2.5G LAN 7.1 Audio mATX Motherboard
GPU: GIGABYTE GeForce RTX 4070 Ti SUPER WINDFORCE OC 16G Graphics Card, 3x WINDFORCE Fans, 16GB 256-bit GDDR6X, GV-N407TSWF3OC-16GD Video Card
PSU: Thermaltake GF1 (2024) Fully Modular ATX 750W Power Supply - 80 PLUS Gold - Ultra Quiet - Zero RPM, PS-TPD-0750FNFAGU-P
CPU: AMD Ryzen 5 7600X - 6-Core 4.7 GHz - Socket AM5 - 105W Desktop Processor (100-100000593WOF)
SSD: SAMSUNG 980 PRO SSD with Heatsink 2TB, PCIe 4.0 M.2 2280, Speeds Up-to 7,000MB/s, Best for High End Computing, Workstations and Compatible with Playstation5 (MZ-V8P2T0CW)
RAM: CORSAIR Vengeance 32GB (2 x 16GB) 288-Pin PC RAM DDR5 5200 (PC5 41600) Desktop Memory Model CMK32GX5M2B5200C40
CPU cooler: DeepCool AK620 High-Performance CPU Cooler, Dual-Tower Design, 2x 120mm Fluid Dynamic Bearing Fans, 6 Copper Heat Pipes, 260W Heat Dissipation, Black.
(All item cost was calculated in the new egg cart) COST $2254.21
Country: Canada
Yes the 4000D Airflow can benefit from another fan. But consider a case that comes with sufficient fans.
Consider an ATX 3.x compliant PSU with native support for the 12VHPWR connector used by the GPU.
Consider a faster memory kit with EXPO profiles.
PCPartPicker Part List
CPU: AMD Ryzen 5 7600X 4.7 GHz 6-Core Processor ($288.98 @ Amazon Canada)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler ($41.90 @ Amazon Canada)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard ($199.98 @ Amazon Canada)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($144.97 @ Newegg Canada)
Storage: Mushkin Vortex Redline 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($218.98 @ Newegg Canada)
Video Card: MSI VENTUS 3X OC GeForce RTX 4070 Ti SUPER 16 GB Video Card ($1129.00 @ Canada Computers)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case ($114.99 @ Amazon Canada)
Power Supply: Thermaltake Toughpower GF3 TT Premium 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($129.99 @ Amazon Canada)
Total: $2268.79
Generated by PCPartPicker 2024-06-12 16:52 EDT-0400
