Looking for mini ITX case: 340 GPU length + 240mm AIO cooler
I already purchased the main components for my next build, including a 14900K CPU and Gigabyte 4090 OC GPU. The GPU requires 340 of clearance, and 3.5 slots. The CPU… obviously requires as much cooling as possible. I was hoping to use JM customize’s Model D case initially, but my GPU is just a tiny bit too large.
(1) So I’m looking for a nice looking case. It doesn’t necessarily have to my mini ITX, but I’d prefer it to be small.
(2) Size is not a deal breaker, but design definitely is. I don’t plan to use RGB, glass sides, or anything showy. I’d prefer a minimalist looking case
(3) For CPU cooling, I either need enough space for a Noctua D15, or at least a 240mm AIO (preferably 360mm)
(3) I’m happy to pay extra for better quality (e.g. all metal design).
In addition to the JM Customized mentioned above, I looked at several options:
(1) the Jonsbo i100, but its GPU clearance in terms of height is slightly insufficient
(2) Fractal Design North: regular version is already pretty card, but for a 340mm long GPU, it won’t allow 360mm radiators in the front. So limited to 240mm for already a pretty large case
(3) Fractal Design Pop: can fit 240AIO and 340mm GPU. But it’s just a bit plain looking…
Any suggestions?
An option to consider:
https://ssupd.co/products/new-meshroom-s
Not stricktly a mitx case, but I am very happy with my Silverstone Alta G1M.
Its a pillar style matx with a very small footprint.
And has a minimalistic look with geometric patterns on the sides.
Comes in black and white.
SilverStone Alta G1M Review | PCMag
https://www.kitguru.net/components/cases/leo-waldock/silverstone-alta-g1m-matx-gets-serious/
mITX is awesome! I regret nothing (apart from when picking parts or have to do maintainance *cough*cough*)
