build with ASUS GeForce RTX® 4090 ROG STRIX OC, 24GB GDDR6X, 384-bit
Go to solution Solved by podkall,
15 minutes ago, victorr1 said:
i build my own list, in witch i went over the buget (ofc), can you please tell me if it's ok?
https://ro.pcpartpicker.com/list/
ye it's good, for more fans you could go one more of these Case Fan: ARCTIC P12 56.3 CFM 120 mm Fan  (39.98RON @ PC Garage)
the Corsair 4000D comes with 2 and you can add one more to the front for example
Budget (including currency): about 1000 dollars (it's flexible)
Country: Romania
Games, programs or workloads that it will be used for: Ai
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):i got this gpu(ASUS GeForce RTX® 4090 ROG STRIX OC, 24GB GDDR6X, 384-bit), and i need a cpu(i would preffer intel, but ryzen works as well), a 1000W source, 64GB RAM and 2TB SSD and a motherboard + coolers for the CPU i want to make sure the components don't bottleneck i will use this build mostly for AI, so i don't think the CPU will be that important. i also need a case. i have the monitors and keyboard + mouse. i plan to use it with 2 monitors, but i don't care about refresh rate.
AM5: (best)
PCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (1096.97RON @ PC Garage)
CPU Cooler: Deepcool AG400 LED 75.89 CFM CPU Cooler  (155.20RON @ PC Garage)
Motherboard: MSI PRO B650-S WIFI ATX AM5 Motherboard  (816.98RON @ PC Garage)
Memory: *ADATA XPG Lancer Blade RGB 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory  (1171.98RON @ PC Garage)
Storage: Western Digital Blue SN580 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (660.35RON @ PC Garage)
Case: Corsair 4000D Airflow ATX Mid Tower Case  (506.98RON @ PC Garage)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (662.05RON @ PC Garage)
Total: 5070.51RON
Generated by PCPartPicker 2024-06-12 19:53 EEST+0300
LGA1700:
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor  (900.28RON @ PC Garage)
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler  (350.71RON @ PC Garage)
Motherboard: Gigabyte B760M GAMING X DDR4 Micro ATX LGA1700 Motherboard  (666.98RON @ PC Garage)
Memory: *ADATA XPG SPECTRIX D35G RGB 64 GB (2 x 32 GB) DDR4-3200 CL16 Memory  (812.93RON @ PC Garage)
Total: 4560.28RON
Generated by PCPartPicker 2024-06-12 19:51 EEST+0300
AM4:
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor  (1006.97RON @ PC Garage)
Motherboard: MSI B550 GAMING GEN3 ATX AM4 Motherboard  (546.98RON @ PC Garage)
Total: 4351.46RON
Generated by PCPartPicker 2024-06-12 19:52 EEST+0300
current PC:
PC configs I used before:
current PC:
2 minutes ago, podkall said:
LGA1700:
Total: 4560.28RON
maybe with Intel get the 1000W PSU, with AMD u can get away with 850W
current PC:
21 minutes ago, podkall said:
AM5: (best)
Total: 5070.51RON
LGA1700:
Total: 4560.28RON
AM4:
Total: 4351.46RON
thanks a lot for the fast response!
do i need extra fans for the build, to circulate the air in the case? (i am new to pc building)
current PC:
additionally, the Motherboard supports CPUs more powerful than 7800x3D/7950x
current PC:
